Raw?
Old 30-11-2008, 10:49 AM   #1
Mr Quint's Avatar
13,035, Level: 27
Points: 13,035, Level: 27 Points: 13,035, Level: 27 Points: 13,035, Level: 27
Activity: 12.1%
Activity: 12.1% Activity: 12.1% Activity: 12.1%
Thanks: Gave 632, Got 164
Raw?
Ok Guys dont laugh.
Just getting to grips with my new Canon 450D.
I have taken some shots in Raw, and had a look at them Via the Canon software that comes with the camera.
However once I have converted the pics to JPEG from RAW (so I can mail them to my friends etc) they seem to lose some quality.
Just wondering, if I can view them in RAW with the software and want my friends to see them in Raw, I supose they need some kind of RAW viewing software rather than Windows Picture & Fax Viewer??
Old 30-11-2008, 10:54 AM   #2
1,952, Level: 10
Points: 1,952, Level: 10 Points: 1,952, Level: 10 Points: 1,952, Level: 10
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 3, Got 3
Re: Raw?
Can't say for canon but I downloaded a plugin from nikon to views RAW(NEF) files in windows.
Had a look, something like this maybe???
clicky
joe
Mr Quint (30-11-2008)
Old 30-11-2008, 11:09 AM   #3
18,258, Level: 32
Points: 18,258, Level: 32 Points: 18,258, Level: 32 Points: 18,258, Level: 32
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 1,222, Got 1,374
Re: Raw?
You could experiment with setting the camera up to capture JPEG & Raw at the same time.
Converting to jpeg shouldn't really degrade the image that much in my experience, I find the biggest problem is that you take the original Raw and don't apply sufficient sharpening in post processing.
Old 30-11-2008, 12:25 PM   #4
johnaalex's Avatar
22,583, Level: 36
Points: 22,583, Level: 36 Points: 22,583, Level: 36 Points: 22,583, Level: 36
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 560, Got 1,186
Re: Raw?
I don't know which application you used for the conversion but most offer you levels of quality (and therefore size) of the final jpg. Maybe you were just a bit keen on getting a small file size?
Old 30-11-2008, 2:56 PM   #5
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: Raw?
clicky
joe
Not unless it supports the 450D though.. However sending RAW files is not generally a god idea as they are large and the end view cannot manipilate them unless they have Lightroom or DPP as well
The DPP software that come with the 450D ( and all Canon DSLRs) is perfect for it
The RAW files are high quality big files uncompressed
The ability to turn them to minimally compressed jpegs reqiure
  • How to use the software Tuturials Here
  • The fact that even as Jpegs the file will be too big to email
If The Op want to send RAW files to his freind fro preview ( not a good idea) . Cam 2 PC will open them
Raw files are uncompressed and with a little skill, the compressed Jpeg ones will look great]If space is not an Issue
Convert then to TiFFs ( which are also large but dot need RAW viewing software)
geoffz (30-11-2008), Mr Quint (30-11-2008)
Old 30-11-2008, 8:56 PM   #6
Mr Quint's Avatar
13,035, Level: 27
Activity: 12.1%
Re: Raw?
Hi guys and thanks for the reply's.
Trust me the Conversion from Raw to Jpeg still gives me stunning results, I was just curious as to how friends could view them in there Raw state.
Thanks for help friends.
Old 30-11-2008, 9:59 PM   #7
1,676, Level: 9
Points: 1,676, Level: 9 Points: 1,676, Level: 9 Points: 1,676, Level: 9
Thanks: Gave 8, Got 5
Re: Raw?
Originally Posted by senu View Post
Thanks for the link to the tutorials , gives me something to do before I can get my hands on my 450D on the 25th .
