Ok so my D40 is in the post to me what lens should I get??
Old 19-11-2008, 8:59 PM   #1
Ned Senior's Avatar
13,490, Level: 27
Points: 13,490, Level: 27 Points: 13,490, Level: 27 Points: 13,490, Level: 27
Thanks: Gave 559, Got 264
Hey how are you
My D40 and 18-55 kit is with royal mail due to be delivered tomorrow, I have a sandisk extreme sdhc 4 Gb on my desk still packaged...
Next month or January I intend to buy a longer lens for shooting ships entering the mersey and also planes taking off at the airport and fighters zooming through the Lake district..
Which should I opt for??
I have a tripod and monopod but will upgrade these basic models in due course
Also is the pantone huey pro worth getting for my crt or should I spend more?? its @£90
Old 19-11-2008, 9:28 PM   #2
6,991, Level: 19
Points: 6,991, Level: 19 Points: 6,991, Level: 19 Points: 6,991, Level: 19
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 614, Got 509
Re: Ok so my D40 is in the post to me what lens should I get??
I have the 55-200 VR lens for my D40, which is great for what it costs, but not sure it's going to be long enough for what you want ?
Might want to look at the 70-300 VR, but that costs a fair bit more. Haven't used it myself, but hear good things about it.
The Sigma 70-300 will be a bit cheaper, but not sure it will be as good - if you go for the Sigma, make sure you get the version that will autofocus on the D40 - I think it's this one - 70-300mm f/4,0-5,6 DG APO Macro - but check before buying.
Ned Senior (19-11-2008)
Old 19-11-2008, 9:42 PM   #3
Ned Senior's Avatar
13,490, Level: 27
Originally Posted by Garf View Post
Cheers the guy at calumet recommended the Nikon VR 70-300 at £319 but I read that there is a sigma at @ £100 so will look in to it thanx for your input
Old 19-11-2008, 9:49 PM   #4
Thanks: Gave 78, Got 67
I'm looking at the Nikon 70-300vr at the moment, but most comments i'm reading say there isnt much to be gained over the 200vr for the extra cost, which is alot
Old 19-11-2008, 9:49 PM   #5
Illustrious Member
sdb123's Avatar
31,232, Level: 43
Points: 31,232, Level: 43 Points: 31,232, Level: 43 Points: 31,232, Level: 43
Thanks: Gave 1,578, Got 2,031
I had the 55-200mm VR and now have the 70-300mm VR....both good lenses with the bigger lens being a step up in quality.
If you get the Sigma lens, try to make sure it has Sigma's HSM (internal motor) to allow auto-focus on the D40.
Old 19-11-2008, 9:55 PM   #6
Ned Senior's Avatar
13,490, Level: 27
do you know is that the @ £100 or the £150 one???
funds are tight so am hoping the lesser
Old 19-11-2008, 10:02 PM   #7
Sorry for the thread hijack, , but better quality....quality of lens, faster focus or quality of images produced, sharper.
Old 19-11-2008, 10:03 PM   #8
Ned Senior's Avatar
13,490, Level: 27
no worries we're all here to ask and learn and share
Old 20-11-2008, 12:02 AM   #9
12,951, Level: 27
Points: 12,951, Level: 27 Points: 12,951, Level: 27 Points: 12,951, Level: 27
Thanks: Gave 36, Got 547
The Sigma 70-300mm APO DG macro is very well regarding (but sorry, it's the £150 one!). Just make sure it's the D40 AF compatible version.
The Nikon 70-300VR is the better lens and the VR will probably negate the need to upgrade your tripod as you'll be able to handhold at 300mm, so the £275 isn't quite as bad is it first appears.
Old 20-11-2008, 12:07 AM   #10
Illustrious Member
sdb123's Avatar
31,232, Level: 43
All of the above.
Old 20-11-2008, 9:00 AM   #11
3,172, Level: 13
Points: 3,172, Level: 13 Points: 3,172, Level: 13 Points: 3,172, Level: 13
Thanks: Gave 57, Got 34
I bought the Sigma 70-300 with internal motor from Onestop Digital and it was £115, I'd wait for the exchange rates to improve as its currently £145 on their site.
Old 20-11-2008, 9:03 AM   #12
booyaka's Avatar
11,393, Level: 25
Points: 11,393, Level: 25 Points: 11,393, Level: 25 Points: 11,393, Level: 25
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 268, Got 679
Sigma 70-300mm f/4-5.6 APO DG Macro Lens
That is the autofocusing one on the D40 - i had one and it's very very good. A little noisey when focusing but otherwise excellent for a budget telephoto & macro lens.
It was £115 when i bought it about 9 months ago but due to the fall in the pound/dollar it's obviously increased in price.
Old 20-11-2008, 6:52 PM   #13
Ned Senior's Avatar
13,490, Level: 27
where have you seen it for £275 ? is it a reputable firm? and does that include postage?
I have a calumet not far away but they want £319
Old 20-11-2008, 7:01 PM   #14
18,065, Level: 32
Points: 18,065, Level: 32 Points: 18,065, Level: 32 Points: 18,065, Level: 32
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Thanks: Gave 1,225, Got 1,376
Quite a few of us use this search engine, I think jessops price looks quite good personally if you've one near :
Nikon AF-S 70-300mm VR from £274.99, UK Specialist Price Comparison Site, Camera Price Buster
Old 20-11-2008, 7:08 PM   #15
Ned Senior's Avatar
13,490, Level: 27
I have two Jessops nearby so yes that would be preferable just hope that the offer you linked to is still on in 28 days, or even better something with a bigger discount!!!
Ned
Yay 1000th post!!!
