Originally Posted by Farno So...just to clarify...If i set the camera to bulb and press the button on the remote and wait say 30mins and press the button again i'll have a 30min exposure or do i have to sit/stand and hold the button in for 30mins?
Sorry  |
Well, for bulb you have to hold the shutter for 30 minutes but that's what remote shutter releases are for. You can press the shutter button and then push it a bit up and it stays pressed if you know what I mean.
ksten, I understand what you are saying but it's good to have a metering chart and see what kind of aperture you will need to get a 30min exposure, with the given metering that your camera gives you for, say f/3.5. But to shoot star trails it means that you'll need to find a place with very little light pollution, so someplace dark. And with a 30 minute exposure, even if you don't see the tree or whatever you are using as foreground interest it will definitely show!
This photo was taken on a very very dark night, 25minutes exposure. I could hardly see the pole infront of me, even after half an hour adjusting to the dark. I manually focused at a distance of 3 meters, used a very small aperture and started the exposure.
Oh and make sure that your batteries are full and that your monitor is turned off while processing the photo, which will probably take the same time as your exposure.
