Nikon 105mm VR Macro- my first pics
Old 02-11-2008, 12:08 PM   #1
3,171, Level: 13
Points: 3,171, Level: 13 Points: 3,171, Level: 13 Points: 3,171, Level: 13
Thanks: Gave 78, Got 31
I picked up this lens last Thursday and had a chance to play with it yesterday. So far the stand-out feature has been the amazing DOF across such a short distance.
It also looks like it's going to be a fantastic portrait lens.
The 1st couple of shots are macro ones of a flower I spotted when out with the dog. The 3rd shot is the aforementioned dog doing her modelling bit !
1 - Flower 1
2 - Flower 2
3 - Tia
Old 02-11-2008, 12:11 PM   #2
12,192, Level: 26
Points: 12,192, Level: 26 Points: 12,192, Level: 26 Points: 12,192, Level: 26
Thanks: Gave 1,130, Got 518
Re: Nikon 105mm VR Macro- my first pics
Super portrait of the mut
Old 02-11-2008, 12:34 PM   #3
Thanks: Gave 78, Got 67
Its on my wish list, nice shot of your dog.
Old 02-11-2008, 2:10 PM   #4
1,698, Level: 9
Points: 1,698, Level: 9 Points: 1,698, Level: 9 Points: 1,698, Level: 9
Thanks: Gave 37, Got 37
Great one of the dog!
Old 02-11-2008, 2:14 PM   #5
johnaalex's Avatar
22,616, Level: 36
Points: 22,616, Level: 36 Points: 22,616, Level: 36 Points: 22,616, Level: 36
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Thanks: Gave 563, Got 1,186
Good looking boxer
On the flower shots you should try using a smaller aperture to get a great depth of field, to balance that for a reasonable shutter speed you may need to up the ISO.
Old 02-11-2008, 2:39 PM   #6
3,171, Level: 13
Both flower shots were taken at f4 with a shutter speed 1/125s.
I figure macro photography will take a wee while to get the hang of.....
Old 02-11-2008, 2:53 PM   #7
johnaalex's Avatar
22,616, Level: 36
Activity: 7.8%
Getting the correct depth of field with Macro work is a bit tricky because of the small distances involved. If you search the web you can easily find a depth of field calculator to show you exactly what I mean. Some of the best macro shots are actually a compilation of shots taken at different focus points and "stacked" to achieve the required effect.
Good luck!
Old 02-11-2008, 3:51 PM   #8
3,171, Level: 13
Thanks for the advice....
I did take a few at smaller apertures. This one was taken at f22 for 1/6s.
Old 02-11-2008, 4:09 PM   #9
TarMoo's Avatar
8,659, Level: 22
Points: 8,659, Level: 22 Points: 8,659, Level: 22 Points: 8,659, Level: 22
Thanks: Gave 200, Got 330
I've taken quite a few flower shots with the 105VR. Quite often I use something around F8.
As a portrait lens you get nice out of focus backgrounds if you use f3.5.
Old 02-11-2008, 4:56 PM   #10
johnaalex's Avatar
22,616, Level: 36
Activity: 7.8%
Nice shot, now you just need to find some flowers before the pests get to them .
