Nikon D60 18-55mm lens - VR or not?
Old 27-10-2008, 10:41 AM   #1
6,142, Level: 18
Points: 6,142, Level: 18 Points: 6,142, Level: 18 Points: 6,142, Level: 18
Thanks: Gave 8, Got 6
Hi all....hopefully you guys can give me some advice. I'm looking to purchase the Nikon D60 with the 18-55mm lens. If I go for this option, is it worth getting the VR version of the lens, or just the standard one?
The VR is about £50 dearer than the standard, and at the moment I have to watch the budget. I'll be purchasing the 55-200mm lens as well, and will definately go for the VR version of this one, but I'm just wondering whether it's worth it on the 18-55mm??
Thanks,
Clive
Old 27-10-2008, 10:49 AM   #2
1,698, Level: 9
Points: 1,698, Level: 9 Points: 1,698, Level: 9 Points: 1,698, Level: 9
Thanks: Gave 37, Got 37
Re: Nikon D60 18-55mm lens - VR or not?
If you look at Camerapricebuster the difference is less than £50. Personally I would get it with VR.
Old 27-10-2008, 11:19 AM   #3
12,951, Level: 27
Points: 12,951, Level: 27 Points: 12,951, Level: 27 Points: 12,951, Level: 27
Thanks: Gave 36, Got 547
Actually the difference is £25 (£300 vs £325), which is a total no-brainer. Go for the VR
VR at the wide end allows static shooting indoors (museums, churches etc) at ridiculously low shutter speeds. I've got away with 1/2 second handheld at 18mm.
Old 27-10-2008, 5:35 PM   #4
rodman's Avatar
2,054, Level: 10
Points: 2,054, Level: 10 Points: 2,054, Level: 10 Points: 2,054, Level: 10
Thanks: Gave 31, Got 30
yes it's worth to have VR on 18-55mm
Old 27-10-2008, 6:10 PM   #5
5,864, Level: 18
Points: 5,864, Level: 18 Points: 5,864, Level: 18 Points: 5,864, Level: 18
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 293, Got 300
I recently was taking photos in a small church near where I live and really wished that I had VR on my 18-70 as I needed to use very slow shutter speeds. If you can afford it then I really would get the VR version - it's not something you 'need' but there are times when it really comes into it's own and you'll kick yourself for not spending the extra few quid on it.
Old 27-10-2008, 7:25 PM   #6
6,142, Level: 18
Hi guys..thanks for all the replies. It seems that the consensus of opinion is that I should go for VR
So be it...I'm gonna make the purchase over the next couple of weeks.
Thanks again, and cheers for now.
Clive
