Sony DSC92
Old 21-06-2003, 4:43 PM   #1
MartinImber's Avatar
13,078, Level: 27
Points: 13,078, Level: 27 Points: 13,078, Level: 27 Points: 13,078, Level: 27
Thanks: Gave 19, Got 24
Sony DSC92
My wife has just purchased one from Jessops £70 off the camera with price match and £9 off each memory stick.
Old 21-06-2003, 6:00 PM   #2
Matt F's Avatar
7,572, Level: 20
Points: 7,572, Level: 20 Points: 7,572, Level: 20 Points: 7,572, Level: 20
Thanks: Gave 0, Got 4
What's the difference between the DSC-P92 and thr DSC-P10?
I thought the slightly dearer P10 might have more exposure control (aperature/shutter priority etc) but apparently not.
Matt.
Old 21-06-2003, 7:47 PM   #3
rags's Avatar
10,985, Level: 25
Points: 10,985, Level: 25 Points: 10,985, Level: 25 Points: 10,985, Level: 25
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 24, Got 54
The only significant diff I can tell is the size - the P10 is considerably smaller. It also comes with a rechargeable battery whereas the 92 takes standard pencils.
Old 22-06-2003, 12:42 AM   #4
seany's Avatar
21,388, Level: 35
Points: 21,388, Level: 35 Points: 21,388, Level: 35 Points: 21,388, Level: 35
How much did you get it for martin?
Old 22-06-2003, 4:20 PM   #5
13,078, Level: 27
She got it for £329 wouldn't price match pix mania but price matched RGB
Old 22-06-2003, 4:32 PM   #6
rags's Avatar
10,985, Level: 25
Activity: 3.0%
Jessops also price match with PRC Direct who have the DSC P10 at £349 - worth the £20 or so over the P92.
Not sure how much RGB are selling the P10 for.
