SD or SDHC?
Old 29-09-2008, 9:42 AM   #1
trailer's Avatar
14,476, Level: 29
Points: 14,476, Level: 29 Points: 14,476, Level: 29 Points: 14,476, Level: 29
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 165, Got 233
SD or SDHC?
Is there any benefit getting an SDHC card over an SD apart from speed?
Old 29-09-2008, 9:50 AM   #2
3,727, Level: 14
Points: 3,727, Level: 14 Points: 3,727, Level: 14 Points: 3,727, Level: 14
Thanks: Gave 58, Got 77
Re: SD or SDHC?
higher capacity and erm speed.
Get the sandisc xtreme 's as they are top notch and at £15 for a 4gb, great value
Old 29-09-2008, 10:12 AM   #3
3,439, Level: 13
Points: 3,439, Level: 13 Points: 3,439, Level: 13 Points: 3,439, Level: 13
Thanks: Gave 24, Got 206
Re: SD or SDHC?
No, but in my experience (and according to some logic regarding chickens and baskets) - its safer to have more smaller cards rather than just one large one. If one fails or gets corrupted, its good to have a backup - so I'd go for more 2gb cards instead of an 8/16gb cards. No real benefit to the SDHC cards unless:
Your file sizes are absolutley huge - eg RAW+uncompressed 16 bit Tiff file / 45megapixel sensor / Shooting high quality video.
Never had a card fail on me but I think some people on here have - it might never happen but you never know.
Old 29-09-2008, 10:15 AM   #4
3,727, Level: 14
Re: SD or SDHC?
bang per buck 4gb cards are the price sweet point. Cards do fail, long write speeds mean more chance for corruption belive it or not. get two 4gb if you are bothered. Fill up a 2gb normal SD card and whilst you are still d/l images, I'll have made a brew and be having a smoke.
Old 29-09-2008, 10:21 AM   #5
RandomLee's Avatar
11,639, Level: 25
Points: 11,639, Level: 25 Points: 11,639, Level: 25 Points: 11,639, Level: 25
Activity: 33.3%
Activity: 33.3% Activity: 33.3% Activity: 33.3%
Thanks: Gave 590, Got 368
Re: SD or SDHC?
Hehe, I like you're logic
Old 29-09-2008, 11:26 AM   #6
5,859, Level: 18
Points: 5,859, Level: 18 Points: 5,859, Level: 18 Points: 5,859, Level: 18
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 293, Got 300
Re: SD or SDHC?
Surely they would also have time for a brew and a smoke while waiting for the images to download?
