Some lighthouses and a white-tailed sea eagle
Old 28-09-2008, 8:41 PM   #1
onefivenine's Avatar
17,895, Level: 32
Points: 17,895, Level: 32 Points: 17,895, Level: 32 Points: 17,895, Level: 32
Thanks: Gave 687, Got 665
We visited the Isle of May in the Firth of Forth recently during a weekend away in Fife.
As per flippin' usual our timing was lousy - the Puffins had just left and the Grey Seals had not yet arrived
... and the weather wasn't exactly playing ball either.
If you do go there, May-July is generally recommended to be the best time.
A few shots nonetheless... otherwise this thread would serve no purpose eh!?
Robert Stevenson Lighthouse
ISO100, 24mm, f/8, 1/25, 0.9 Hard GND
(Disused) Low Light lighthouse, now used as a bird observatory.
ISO100, 140mm, f/8, 1/160, 0.9 Hard GND
A Coal-fired Beacon was established on the Isle of May in 1635.
ISO100, 40mm, f/8, 1/50, 0.9 Hard GND
Foghorn & White-Tailed Sea Eagle
ISO100, 280mm (1.4x extender), f/8, 1/160, 0.6 Soft GND
(ok you do need to view it full size to really make it out )
