Monitor profiling software?
Old 14-09-2008, 12:59 PM   #1
Gordon @ Convergent AV's Avatar
41,374, Level: 49
Points: 41,374, Level: 49 Points: 41,374, Level: 49 Points: 41,374, Level: 49
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 984, Got 1,705
I'm having a bad time here with my printer and laptop monitor. I've just got a custom profile back for the printer and paper I use (excellent service from permajet, turned it around in a day!). However the prints don't match the monitor particularily.
So I guess I need to calibrate the monitor and create a new ICC profile. I have expensive hardware but I don't have the funds for software to do this. Does anyone know of any free software that will do the profiling and can talk to x-rite/gretagmcbeth i1Pro spectrophotometer?
Old 14-09-2008, 4:22 PM   #2
8,488, Level: 22
Points: 8,488, Level: 22 Points: 8,488, Level: 22 Points: 8,488, Level: 22
Thanks: Gave 13, Got 64
Re: Monitor profiling software?
i have used some freeware software called argyll cms before - its not the most user friendly - its all cli but it is very comprehensive
Gordon @ Convergent AV (14-09-2008)
Old 14-09-2008, 7:32 PM   #3
8,308, Level: 21
Points: 8,308, Level: 21 Points: 8,308, Level: 21 Points: 8,308, Level: 21
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 27, Got 8
I would try looking at coloreyes display pro - I work in colour management for print and repro and it's very good software.
You can download the demo which allows 10 "launches" in 10 days (check your PM).
Cheers,
Matthew
