Double moon? Why??
Old 09-08-2008, 9:59 AM   #1
mypspname's Avatar
1,734, Level: 9
Points: 1,734, Level: 9 Points: 1,734, Level: 9 Points: 1,734, Level: 9
Thanks: Gave 54, Got 20
Double moon? Why??
Please help! see the pic.. why the ghost image (second moon)?? what can I do to avoid it?? Tia.
Old 09-08-2008, 10:03 AM   #2
ijd ijd is offline
8,735, Level: 22
Points: 8,735, Level: 22 Points: 8,735, Level: 22 Points: 8,735, Level: 22
Thanks: Gave 105, Got 154
Re: Double moon? Why??
use a polarizing filter
Old 09-08-2008, 10:35 AM   #3
3,903, Level: 14
Points: 3,903, Level: 14 Points: 3,903, Level: 14 Points: 3,903, Level: 14
Thanks: Gave 10, Got 45
That's no moon - it's a space station
Sorry couldn't resist
Old 09-08-2008, 11:06 AM   #4
5,840, Level: 18
Points: 5,840, Level: 18 Points: 5,840, Level: 18 Points: 5,840, Level: 18
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 148, Got 297
My guess is that you had a skylight / UV filter on the lens. Remove the filter & you won't get this.
ijd's suggestion that you use a polarizer might help to reduce the reflection from the surface of the water but it won't correct the ghosting.
mypspname (09-08-2008)
Old 09-08-2008, 1:44 PM   #5
geniusworkin's Avatar
Thanks: Gave 8, Got 44
cant you edit it out ?
im sure any photo editing suite will have that funtionality.
gw
Old 09-08-2008, 5:39 PM   #6
mypspname's Avatar
1,734, Level: 9
Thanks guys.. maybe that was the UV filter. I'll try removing it.
Old 09-08-2008, 7:18 PM   #7
ryanyboy's Avatar
4,362, Level: 15
Points: 4,362, Level: 15 Points: 4,362, Level: 15 Points: 4,362, Level: 15
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 242, Got 174
Nah, it's to big to be a space station....
Couldn't resist it either!
