Help, Nikon 55-200mm Lens....
Old 26-07-2008, 4:32 PM   #1
SatDude's Avatar
5,946, Level: 18
Points: 5,946, Level: 18 Points: 5,946, Level: 18 Points: 5,946, Level: 18
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 50, Got 36
Hi All,
A couple of weeks ago I bought a Nikon D40 after reading loads on the forum...
I’ve only got the 18-55mm lens that came with it but I would like to get some more zoom, i think it’s now time to buy some more kit, I think the 55-200 lens will be good for me now and I’ve been looking at the VR ones at Jessop’s but seen these ones at Argos today, it seems like the same lens but £100 less... What do you think? Is that cheap? What’s the catch?
Jessops - Nikon 55-200mm f/4.-5.6 AFS DX VR Lens (Black) (£249.99)
Argos - Nikon 55-200 DX Lens (£149.96)
The titles are different but they look the same to me...
Thanks!
Old 26-07-2008, 4:34 PM   #2
Liquid101's Avatar
15,145, Level: 29
Points: 15,145, Level: 29 Points: 15,145, Level: 29 Points: 15,145, Level: 29
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 599, Got 1,489
Re: Help, Nikon 55-200mm Lens....
The difference is VR (Vibration Reduction) The more expensive version has it, the cheaper doesn't.
SatDude (26-07-2008)
Old 26-07-2008, 4:39 PM   #3
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
I was looking at that 2, and then looked at the photo argos have on their website, it's the vr lens on the picture but... that means nothing.
Now, having googled for the 55-200 VR the cheapest i could find was £150.....
I'll go to Argos tomorrow to confirm if they are selling the VR or not.
Old 26-07-2008, 4:44 PM   #4
Liquid101's Avatar
15,145, Level: 29
Activity: 9.1%
Good point - didn't spot the VR on the picture of the Argos one. A quick look at this shows that it can be had for as little as £127 - but the supplier is questionable.
Old 26-07-2008, 4:51 PM   #5
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
That's the problem... would you recomend this lens for a newbie? I'm happy with the 18-55mm but need more zoom in some ocasions... I think the 70-300mm will be too much.
Old 26-07-2008, 4:56 PM   #6
9,316, Level: 23
Points: 9,316, Level: 23 Points: 9,316, Level: 23 Points: 9,316, Level: 23
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 250, Got 271
Try THIS. I used them a few times and so people from here as well i think.
Fast delivery and also the warranty valid for Nikon UK as Nikon lens gets international warranty
Old 26-07-2008, 9:53 PM   #7
3,727, Level: 14
Points: 3,727, Level: 14 Points: 3,727, Level: 14 Points: 3,727, Level: 14
Thanks: Gave 58, Got 77
Price checker here
I got this lens and more than happy with it. You really need the VR though as its not a fast lens hence the price.
