Insect sheds it's skin
Old 21-07-2008, 1:04 PM   #1
Mike.P®'s Avatar
8,751, Level: 22
Points: 8,751, Level: 22 Points: 8,751, Level: 22 Points: 8,751, Level: 22
Thanks: Gave 479, Got 449
The other day I posted this photo of the unknown insect with a wasp on it's head. After a few days the thing has still not moved so decided to prod it and see what occured.
Nothing happened so picked it up and low and behold its just the skin left so brought it inside (much to the disgust of the wife) and take a couple of photos.
Old 21-07-2008, 1:10 PM   #2
kBm kBm is offline
kBm's Avatar
13,703, Level: 28
Points: 13,703, Level: 28 Points: 13,703, Level: 28 Points: 13,703, Level: 28
Activity: 14.0%
Activity: 14.0% Activity: 14.0% Activity: 14.0%
Thanks: Gave 473, Got 766
Re: Insect sheds it's skin
While its an excellent shot ...
... it gives me the creeps!
Old 21-07-2008, 1:11 PM   #3
11,514, Level: 25
Points: 11,514, Level: 25 Points: 11,514, Level: 25 Points: 11,514, Level: 25
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 90, Got 101
Cool. Now you have the skin at your disposal, you might want to take a photo with a different background, and also with better lighting to remove the shadow.
Old 21-07-2008, 1:14 PM   #4
Mike.P®'s Avatar
8,751, Level: 22
While I agree with you on the background (a pine sideboard is probably not that good a backdrop tbh) I think the shadow gives it a more menacing look
Old 21-07-2008, 1:29 PM   #5
11,514, Level: 25
Activity: 1.5%
Possibly - how about using an off camera flash, so the shadow is slightly to the side. Not that I want to give you extra work for the sake of it
Does the first pic look better as is, or rotated? It's making me dizzy.
Old 21-07-2008, 1:32 PM   #6
Mike.P®'s Avatar
8,751, Level: 22
Actually you are right there, the first pic may look better rotated.
As for off camera flash, not got that far in my photographic equipment .. not had a dslr that long so still working on the basics
Old 21-07-2008, 1:35 PM   #7
kBm kBm is offline
kBm's Avatar
13,703, Level: 28
Activity: 14.0%
If you want menacing...
Dark room, dark backdrop, use a LED light as a light source and a slow shutter.....
