Circular Polarizer
Old 13-07-2008, 5:18 PM   #1
ryanyboy's Avatar
4,362, Level: 15
Points: 4,362, Level: 15 Points: 4,362, Level: 15 Points: 4,362, Level: 15
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 242, Got 174
Circular Polarizer
Hi all.
Could anyone recommend a decent circular polarizer to go on my Canon 24-105 F/4.0 L IS lens?
I have a Hoya Pro1 D polarizer on my 17-85 F/5-5.6 IS USM lens but I'm not convinced it's as good as it could be - the quality doesn't seem great.
Is it important to use a polarizer made for digital cameras? That seems odd to me.
Any suggestions would be greatly appreciated.
Many thanks for reading,
Ryan
Old 13-07-2008, 5:40 PM   #2
18,426, Level: 32
Points: 18,426, Level: 32 Points: 18,426, Level: 32 Points: 18,426, Level: 32
Thanks: Gave 310, Got 933
Re: Circular Polarizer
I use a 77mm Hoya one on my 24-105. Quality of the glass is good and it polarises well, but I've had the glass separate from the screw-in bit a couple of times which is disappointing. Usually this happens when I'm unscrewing it and being a bit too forceful.
ryanyboy (13-07-2008)
