noticed the cheaper extension tubes on ebay are 9mm, 16mm, 30mm lens
the kenko are 12 mm, 20 mm, and 36 mm
im not really bothered about brands etc as m just starting macro, so just want some cheaper version for now.
questions is the cheaper version tube has 30mm and kenko has 36mm does this mean the kenko gets n more closer than the cheaper version due to the kenko being 36mm? im curious regarding the diffrence between the two?
also can someone also suggest a decent flash for macro work as also heard with cheaper tubes theres no metering & hard to see any light at all with tubes so what guess will need to buy a decent flash too as ony have the built in at he moment.
