Originally Posted by baldrick For the cheaper cost you could have a play with the Cokin stuff and see what you actually need, then splash out on the Lee filters.... |
To be honest I don't need to try the plain ND, it's obvious what it does and with my D70 only going down to ISO200 (same as D300) I know I want a good few stops.
So to test 1 graduated nd would cost:
option 1, buy cokin P kit
cokin p wide angle holder (£8.70), 77mm P ring (£6.75), graduated nd filters £12.90 each, = £28.35
option 2, buy cokin Z filter
£35 each - if these fit in the Lee system, I'd rather have a cokin Z filter at the end, that I can use, than cokin P stucff I don't want.
or Lee resin graduated filters cost £55, but a little cheaper if you get the ones available with the kit.
My gut feeling is that the 2 stop Pro glass ND filter will be a waste of time for me. The 2 stop ND grad hard will be useful, but I'd rather a 3 stop, so I may as well buy the Lee system individually, perhaps starting with 1 grad, seeing how I get on and then buying others when I know what more I need.
Originally Posted by springtide Thats exactly right, you screw this on the lens prior to using the Lee adapter. It's a bit of a fiddle with the wide angle adapter as the screw thread is 'countersunk'.
Due to the 'countersunk' issue, trying to use a CIL POL in this way is more than a fiddle, since once attached it's almost impossible to unscrew without breaking the filter into two (I'm pretty good as putting them back together now though) |
Typical that my new Cir PL has just arrived in the post (although even if I have to buy another PL to go in the Lee system, this one will still be useful for when I dont carry the whole kit).
I'm not wanting to be overly creative with filters. I simply want an ND for flowing water, a grad (choice of grads, but use 1 at a time) to darken skies (or the odd other bright object) and a poloriser. I want to avoid putting too much if front of the lens, but I guess there could be times when I need all 3 of those filters. It's a shame that Lee don't have as many stops as B+W (which are well recommened) and B+W don't do filters to go in the Lee system (I think they're just screw in aren't they?).
