Spot the difference?
Old 09-05-2008, 10:14 AM   #1
3,170, Level: 13
Points: 3,170, Level: 13 Points: 3,170, Level: 13 Points: 3,170, Level: 13
Thanks: Gave 6, Got 1
Query please..
If one was to buy/sell a kit lens is there any way you can tell its from a kit and not bought initially as a separate item?
Alan
Old 09-05-2008, 10:21 AM   #2
5,201, Level: 17
Points: 5,201, Level: 17 Points: 5,201, Level: 17 Points: 5,201, Level: 17
Thanks: Gave 62, Got 106
Re: Spot the difference?
Not really, only difference is that it doesnt come in a box. The Canon 18-55mm with a plastic mount is only available as a kit though (I think - please correct me if im wrong)
Old 09-05-2008, 10:58 AM   #3
allymac123's Avatar
9,729, Level: 23
Points: 9,729, Level: 23 Points: 9,729, Level: 23 Points: 9,729, Level: 23
Thanks: Gave 489, Got 451
There wouldn't be a box if it was bought as a kit. (it comes in the same box as the camera.)
At the end of the day what would it matter. It's not going to effect the performance of the lens.
Old 09-05-2008, 3:35 PM   #4
3,170, Level: 13
Thanks for replies... My Camera box states 40D SLR camera + EF-S 17-55mm IS USM lens kit. The lens itself was in a separate box on its own. Just wondering.
Regards
Alan
