Nikon D40....anybody cleaned the sensor?
Old 07-04-2008, 6:44 PM   #1
8,089, Level: 21
Points: 8,089, Level: 21 Points: 8,089, Level: 21 Points: 8,089, Level: 21
Thanks: Gave 0, Got 5
Got a mark on my pictures and want to clean the sensor with a rocket blower.
According to the manual I need to select Mirror Lock Up from the set-up menu.
But this option isn't appearing in the set-up menu.
Am I missing something?
Battery is fully charged.
Any ideas?
Old 07-04-2008, 7:17 PM   #2
12,951, Level: 27
Points: 12,951, Level: 27 Points: 12,951, Level: 27 Points: 12,951, Level: 27
Thanks: Gave 36, Got 547
Re: Nikon D40....anybody cleaned the sensor?
Try scrolling down. I think the lockup is off the bottom of the page (see linky below).
http://www.dpreview.com/reviews/NikonD40/page11.asp
Also blow on the rear element of your lens, a dust bunny there will actually be more visible than on the sensor. Don't be too suprised or worried if you blow dust or other junk up into the focussing screen. I think my resident population of dustballs just moves around between sensor, screen, mirror and lens, just to torment me!
Old 07-04-2008, 7:40 PM   #3
Liquid101's Avatar
15,138, Level: 29
Points: 15,138, Level: 29 Points: 15,138, Level: 29 Points: 15,138, Level: 29
Activity: 10.6%
Activity: 10.6% Activity: 10.6% Activity: 10.6%
Thanks: Gave 596, Got 1,488
I'm not sure about the D40, but the D50 needs to have the CSM/Menu Setup on 'Detailed', rather than 'Simple' to use this function.
Old 07-04-2008, 8:43 PM   #4
6,030, Level: 18
Points: 6,030, Level: 18 Points: 6,030, Level: 18 Points: 6,030, Level: 18
Press the menu button, select the setup menu(the spanner) press ok and then scroll down, mirror lockup is 4th option from the bottom then press ok again.
Old 07-04-2008, 8:57 PM   #5
8,089, Level: 21
Thanks for that. I needed to change the Menu/Set-up from Simple to Full for it to show.
