Tokina 19-35mm (Opinion/Recommend/Advice)
Old 25-03-2008, 8:15 PM   #1
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Ah harr!
I've found this gem (I think).
Tokina 19-35mm f/3.5-4.5
On the Minolta/Sony side, it gets a high rating. Has onyone used or owned one of these (any body brand) and could you offer your opinion/review of it please?
Old 25-03-2008, 8:29 PM   #2
16,655, Level: 31
Points: 16,655, Level: 31 Points: 16,655, Level: 31 Points: 16,655, Level: 31
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,218, Got 968
Re: Tokina 19-35mm (Opinion/Recommend/Advice)
Hello there
Not got bad reviews here Suppose its not a bad price.
IMHO I would like something a bit faster at that range.
Cheers Holo
Old 25-03-2008, 8:34 PM   #3
Pirate!!'s Avatar
22,390, Level: 36
Activity: 23.1%
Originally Posted by Holowlegs View Post
Hello there
Cheers Holo
OK, deduct speed from price. Would you buy one for £99.00? Is there anything else close at that money?
