Polarising Filter
Old 25-03-2008, 7:47 PM   #1
5,959, Level: 18
Points: 5,959, Level: 18 Points: 5,959, Level: 18 Points: 5,959, Level: 18
Thanks: Gave 63, Got 46
Polarising Filter
58mm
Can someone recommend a brand and from where to buy, are the cheap ones on ebay a no no?
Thanks in advance
Old 25-03-2008, 7:52 PM   #2
16,655, Level: 31
Points: 16,655, Level: 31 Points: 16,655, Level: 31 Points: 16,655, Level: 31
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,218, Got 968
Re: Polarising Filter
Hello there
Go on you RRR'S
Had to do that
Got mine from onestop. Hoya 58mm Circular Polarizing Glass Filter £19.99
Cheers Holo
U'R'ss (25-03-2008)
Old 25-03-2008, 8:13 PM   #3
6,102, Level: 18
Points: 6,102, Level: 18 Points: 6,102, Level: 18 Points: 6,102, Level: 18
Thanks: Gave 144, Got 84
Could always get one from Argos Here I got one and it seems to do the job,cheap as chips.
U'R'ss (25-03-2008)
Old 25-03-2008, 8:57 PM   #4
jonnypb's Avatar
13,765, Level: 28
Points: 13,765, Level: 28 Points: 13,765, Level: 28 Points: 13,765, Level: 28
Thanks: Gave 319, Got 590
I'd go with a hoya
U'R'ss (25-03-2008)
Old 25-03-2008, 9:07 PM   #5
geofftelforduk's Avatar
11,339, Level: 25
Points: 11,339, Level: 25 Points: 11,339, Level: 25 Points: 11,339, Level: 25
Thanks: Gave 63, Got 155
Try the Cokin P Series and Cokin Circular Polariser from 7dayshop!!
U'R'ss (25-03-2008)
Old 25-03-2008, 9:15 PM   #6
onefivenine's Avatar
17,895, Level: 32
Points: 17,895, Level: 32 Points: 17,895, Level: 32 Points: 17,895, Level: 32
Thanks: Gave 687, Got 665
I'd recommend investing a bit more on a Hoya Pro-1 Digital. It's worth it.
£30 here.
U'R'ss (25-03-2008)
Old 25-03-2008, 10:07 PM   #7
jenufa's Avatar
7,913, Level: 21
Points: 7,913, Level: 21 Points: 7,913, Level: 21 Points: 7,913, Level: 21
Thanks: Gave 151, Got 123
Originally Posted by Holowlegs View Post
Hello there
Go on you RRR'S
Had to do that
Cheers Holo
Same here from OneStop.
Come on you Hoops
U'R'ss (25-03-2008)
Old 25-03-2008, 10:53 PM   #8
5,959, Level: 18
Hello there
Go on you RRR'S
Had to do that
Cheers Holo
Old 25-03-2008, 10:55 PM   #9
5,959, Level: 18
We are the Rangers Boys
Old 25-03-2008, 10:57 PM   #10
5,959, Level: 18
£30 here.
Thanks, that sounds cheap
