cannon EOS40D LCD SCREEN PROBLEM,HELP
Old 25-03-2008, 6:48 PM   #1
2,546, Level: 11
Points: 2,546, Level: 11 Points: 2,546, Level: 11 Points: 2,546, Level: 11
Thanks: Gave 1, Got 0
Hi,can the lcd screen be turned of so only the viewfinder is used ? mine hase gone of but still shows the pictures when taken and also still allows pictures to be viewed but i cannot find anything in instructions to help,am i missing something or is it a fault?
Old 25-03-2008, 7:25 PM   #2
Luffy's Avatar
8,687, Level: 22
Points: 8,687, Level: 22 Points: 8,687, Level: 22 Points: 8,687, Level: 22
Thanks: Gave 111, Got 83
Re: cannon EOS40D LCD SCREEN PROBLEM,HELP
Are you talking about the rear screen
do you mean the live view is not working
or are you talking about the LCD screen on the top panel
Old 25-03-2008, 7:27 PM   #3
Luffy's Avatar
8,687, Level: 22
Re read your post sounds like the rear screen
if you have live view activated you normally press the select button to turn it on its not normal to use it all the time for normal shooting I only use it when mounted on a tri pod
bell4796 (25-03-2008)
Old 25-03-2008, 7:31 PM   #4
2,546, Level: 11
thanks,yes it is the rear screen ,any ideas
Old 25-03-2008, 7:34 PM   #5
2,546, Level: 11
up and runnung thanks very much
Old 25-03-2008, 7:40 PM   #6
2,546, Level: 11
No i am not up and running ,thought it was back on but it was not,the camera is set in live view mode but the rear screen is not on.
Old 25-03-2008, 7:45 PM   #7
2,546, Level: 11
i am now up and running and i now know what i was doing wrongthanks again
