Workflow advice required, but keep it simple!
Old 19-03-2008, 8:44 PM   #1
tontoshorse's Avatar
12,395, Level: 26
Points: 12,395, Level: 26 Points: 12,395, Level: 26 Points: 12,395, Level: 26
Thanks: Gave 775, Got 693
evening, whats the best workflow to save/send images to be printed?
Till now i haven't been to bothered on picture quality as my print size has been fairly small.
I normally just save my RAW file to JPEG in Elements to the highest setting and email that jpeg.
Should I resize the image or use a different file type, etc etc?
Is there a better way?
many thanks.
Old 19-03-2008, 9:55 PM   #2
Radiohead's Avatar
15,086, Level: 29
Points: 15,086, Level: 29 Points: 15,086, Level: 29 Points: 15,086, Level: 29
Thanks: Gave 327, Got 450
Re: Workflow advice required, but keep it simple!
Who are you using for printing?
Some pro labs will ask for Pro Photo or Adobe RGB colour profiles, and for ultimate quality you want to be using TIFF anyway.
Old 20-03-2008, 5:35 PM   #3
12,395, Level: 26
Thanks Guy, i normally use photobox.
What are the setting to use in CS2 to get Tiff and what's a colour profile??
