D40 battery grip
Old 06-03-2008, 4:05 PM   #1
ScottBT's Avatar
4,996, Level: 16
Points: 4,996, Level: 16 Points: 4,996, Level: 16 Points: 4,996, Level: 16
Thanks: Gave 9, Got 56
D40 battery grip
Does this grip look ok: http://cgi.ebay.co.uk/Battery-Vertic...QQcmdZViewItem Item number: 200204086931
I know the D40 is small and compact but I have large hands and the D80/200 was way out my price range when I bought the D40.
Using the 70-300VR you need a firm grip and I now have the Sigma 12-24 HSM which is also a heavy lens on the D40.
Ok so the vertical grip uses the remote setting but I probably never use it anyway.
Any thoughts?
Old 06-03-2008, 7:48 PM   #2
12,192, Level: 26
Points: 12,192, Level: 26 Points: 12,192, Level: 26 Points: 12,192, Level: 26
Thanks: Gave 1,130, Got 518
Re: D40 battery grip
For £30 i`d think it`s worth giving it a go. If you don`t get on with it, i`m sure one of us will have it off your hands
Old 07-03-2008, 2:56 PM   #3
ScottBT's Avatar
4,996, Level: 16
Well I bought it, so we'll see.
It's only for comfort anyway so hopefully it'll be fine.
Old 07-03-2008, 4:30 PM   #4
12,192, Level: 26
I`d be interested to know how you get on with it. Keep us updated please.
