Help - how do I improve my photos with my Pana Fx33
Old 01-03-2008, 11:05 AM   #1
slowpoke's Avatar
5,838, Level: 18
Points: 5,838, Level: 18 Points: 5,838, Level: 18 Points: 5,838, Level: 18
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 12, Got 15
I know its a point and click camera but what do i need to change on the settings etc for different types of photos...cheers1
Old 01-03-2008, 2:14 PM   #2
slowpoke's Avatar
5,838, Level: 18
Activity: 0.7%
Re: Help - how do I improve my photos with my Pana Fx33
anyone for anyone please!!!
Old 01-03-2008, 3:14 PM   #3
tontoshorse's Avatar
12,395, Level: 26
Points: 12,395, Level: 26 Points: 12,395, Level: 26 Points: 12,395, Level: 26
Thanks: Gave 775, Got 693
Hi, what is it you're trying to do?
There's an awful lot of settings to consider.
Old 01-03-2008, 3:24 PM   #4
slowpoke's Avatar
5,838, Level: 18
Activity: 0.7%
Hi tonto, I really dont have a clue at all, are there any begginners tips thats helps me understand what each setting does?
Old 01-03-2008, 3:43 PM   #5
12,395, Level: 26
TBH the manual is a good place to start.
However, if you list the settings which are giving you grief I'm sure assistance will wing your way.
Old 01-03-2008, 4:12 PM   #6
5,242, Level: 17
Points: 5,242, Level: 17 Points: 5,242, Level: 17 Points: 5,242, Level: 17
Thanks: Gave 2, Got 170
One of the best ways to learn is by your mistakes. If you post some photos that you think can be improved then we can give you help.
If you don't know how to post photos, a quick search of the forum will provide the answer.
At the moment your question is too vague!
Old 01-03-2008, 4:23 PM   #7
slowpoke's Avatar
5,838, Level: 18
Activity: 0.7%
OK, for starters what do the ISO settings mean?
Also I have tried to set the camera to high speed bursts and when I shoot it doent do anything different...any ideas? cheers
Old 01-03-2008, 4:32 PM   #8
5,242, Level: 17
ISO settings change how sensitive the camera is to light. High ISO (on a compact, probably around 400) lets you shot in the dark with faster shutter speeds - less blur. The problem is that as you increase the ISO, the image quality decreases - you get 'noise' in the photo.
Read these for mroe info:
http://www.dpreview.com/learn/?/Glos...xposure_01.htm
http://www.dpreview.com/learn/?/Glos...g/Noise_01.htm
High speed burst means you can take a lot of pictures in quick succession - hold down the shutter button and watch that memory card fill up! Useful for action sequences or for shooting fast moving objects where 'the' moment lasts only miliseconds - the more photos you take during that fraction of a second the better a chance you have of getting the shot you want.
Old 01-03-2008, 7:54 PM   #9
slowpoke's Avatar
5,838, Level: 18
Activity: 0.7%
Thanks, that helps alot though when I use the high speed burst it doesnt work
