Exposure correction PP
Old 29-02-2008, 12:32 PM   #1
8,470, Level: 22
Points: 8,470, Level: 22 Points: 8,470, Level: 22 Points: 8,470, Level: 22
Thanks: Gave 17, Got 8
I know there are various methods of correcting poor exposures PP, but after a search on google i came across this tutorial:
http://tutorialpulse.com/45/brighten-photos-like-a-pro/
It seems to have an advantage over raising curves/ levels etc in that it doesn't blow out the highlights. I am not sure if there is much difference in it and Highlight/Shadows tool.
I tried this last night on a night shot of a lit building and on a backlit daylit portrait taken outside (foreground very dark).
I was impressed with the outcome, and the fact that no matter how much i turned up the brightness using this method, it only brightened the dark to light areas proprtionally, ensuring no blown highlights.
Are there any other similar methods which people use which also provide good results??
JD
sbowler (29-02-2008)
Old 29-02-2008, 12:43 PM   #2
12,951, Level: 27
Points: 12,951, Level: 27 Points: 12,951, Level: 27 Points: 12,951, Level: 27
Thanks: Gave 36, Got 547
Re: Exposure correction PP
Originally Posted by johndow View Post
I
JD
Yep, if you're a Nikon shooter - shoot RAW and use Capture NX.
You've then got +/-2ev exposure compensation As with half of the NX features, it's some kind of voodoo magic trick (extrapolating data from the other colour channels?)...but it works! Unless you've been particularly hamfisted with your in-camera exposure you can rescue pretty much any lost detail.
Old 29-02-2008, 1:07 PM   #3
sbowler's Avatar
11,173, Level: 25
Points: 11,173, Level: 25 Points: 11,173, Level: 25 Points: 11,173, Level: 25
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 131, Got 497
Great for us Pentax users.
Old 29-02-2008, 1:34 PM   #4
ScottBT's Avatar
4,996, Level: 16
Points: 4,996, Level: 16 Points: 4,996, Level: 16 Points: 4,996, Level: 16
Thanks: Gave 9, Got 56
Agreed, NX is fantastic for any RAW Nikon images.
