Need some help deciding on a camera...
Old 21-02-2008, 6:40 PM   #1
4,757, Level: 16
Points: 4,757, Level: 16 Points: 4,757, Level: 16 Points: 4,757, Level: 16
Lightbulb Need some help deciding on a camera...
Hi all,
I've decided to invest in a digital camera as my iPhone is quite poor in a lot of conditions and doesn't exactly have much functionality!
I am looking for a camera that costs less than £200, ideally.
It will mostly be used for taking pictures of my college projects, friends, and the odd scene or close up on something interesting (for the budding photographer inside me).
I have been looking at the Panasonic Lumix FZ8 but wanted to know whether there was a more 'bang for buck' camera I could get.
Thank you all.
Old 21-02-2008, 10:56 PM   #2
Conspicuous Member
nero0410's Avatar
22,345, Level: 36
Points: 22,345, Level: 36 Points: 22,345, Level: 36 Points: 22,345, Level: 36
Activity: 33.1%
Activity: 33.1% Activity: 33.1% Activity: 33.1%
Thanks: Gave 2,110, Got 809
Re: Need some help deciding on a camera...
Looking to invest in a new camera with more of a zoom, and found this which may be worth considering:
http://www.digitalrev.com/en/product...p?item_id=1124
tris
Old 22-02-2008, 7:26 AM   #3
bibamus's Avatar
3,839, Level: 14
Points: 3,839, Level: 14 Points: 3,839, Level: 14 Points: 3,839, Level: 14
Thanks: Gave 14, Got 39
Canon Powershot A720is gets very good reviews. I had the A710is and couldnt fault it. You should get one for between £120 - £150, Jessops have it on offer at £149
Heres a review.
http://www.dpreview.com/reviews/canona720is/
Allan
Old 22-02-2008, 7:32 AM   #4
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Originally Posted by Shoxz View Post
Panasonic Lumix FZ8. Wanted to know whether there was a more 'bang for buck' camera I could get.
Don't think so.
Old 22-02-2008, 7:35 AM   #5
Pirate!!'s Avatar
22,390, Level: 36
Activity: 23.1%
tris
S3 IS is old and not that good. Personally, I would avoid it.
Old 22-02-2008, 8:29 AM   #6
Conspicuous Member
nero0410's Avatar
22,345, Level: 36
Activity: 33.1%
Heres a review.
Allan
Same as the old dots, and is a cracking little camera IMOH
Thanks for the advice
tris
Old 22-02-2008, 5:24 PM   #7
4,757, Level: 16
Thanks guys.
Any opinions on this camera:
http://www.ebuyer.com/product/131849
I searched but couldn't really find any detailed information about it.
It looks very nice and I looked at some of the pictures on Flickr of the model below it and they were fantastic...
Thanks!
Old 22-02-2008, 6:31 PM   #8
Pirate!!'s Avatar
22,390, Level: 36
Activity: 23.1%
I have an opinion (FWIW). Aparently the colour rendition is meant to be OK. AA batteries suck and there's no image stabilisation (Fuji's version of OIS is to automatically adjust shutter speed and ISO - which sucks even more).
Research reviews on DPReview if you find something you think is on the short list. The S9600 might be a better option if you want to carry a pocketload of AA's around.
You asked for opinions. This is mine.
Old 22-02-2008, 9:02 PM   #9
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
The Gospel according to.....
Pirate is actually right on the ball there Hes also very right about the Lumix being the best for the money...
Old 22-02-2008, 9:12 PM   #10
Conspicuous Member
nero0410's Avatar
22,345, Level: 36
Activity: 33.1%
And for £217.99 (ok bout £30 more) you can have a whopping 18x zoom and IS
From egears.oc.uk (not used them so might be worth checking them out first
http://www.dpreview.com/reviews/panasonicfz18/
tris
Old 23-02-2008, 11:14 AM   #11
Pirate!!'s Avatar
22,390, Level: 36
Activity: 23.1%
The IQ isn't as good as the FZ8, but the wider angle and longer range might be useful. I'd opt for the 8 over the 18 personally. The extra ££'s for the 18 (IMHO) isn't justified. If you're spending that kinda money, you'd may as well go for the FZ50.
Old 23-02-2008, 3:57 PM   #12
Conspicuous Member
nero0410's Avatar
22,345, Level: 36
Activity: 33.1%
It's the wider angle and longer zoom range that I'm looking at, and the FZ50 is about £80 more from what I can find and only has a 12xzoom opposed to a x18.
Still looking for whats about though
tris
