Gunthorpe Bridge
Old 16-02-2008, 7:46 PM   #1
3,303, Level: 13
Points: 3,303, Level: 13 Points: 3,303, Level: 13 Points: 3,303, Level: 13
Thanks: Gave 56, Got 56
Gunthorpe Bridge (sun and moon)
Was out and about today and decided to get my new Manfrotto 055proB and 410 geared head out of the boot. Didn't have much time, so it was just a quick shot. Quite pleased with the results though, can't wait until I've got a bit more time to spend.
Exif should be preserved in the image.
Removed a bit of lense flare and adjusted levels etc. The shots a bit noisey and the jpeg conversion from RAW isn't the best but it'll do for now. C+C welcome.
Also took one of the moon. Only had my 24-105 with me, so there's a bit of cropping going on (hence the noise). Nowhere near what others are producing of the moon, maybe it's time to start looking on ebay for a cheap-ish telescope.
Old 17-02-2008, 11:29 AM   #2
3,303, Level: 13
Re: Gunthorpe Bridge
Just had a play with the moon shot after seeing someone else use fractalius on the moon.
