Originally Posted by dazza74 "Yandros" is your man for the 18-200mm VR, might be worth a quick look at the 18-200mm VR got mentioned a bit here : Lens confusing |
You called?
The 18-200VR is of almost identical optical quality to the Nikon 18-70, but offers you a LOT more functionality. The VR AND the extra reach make it a no-brainer over the 18-70 if you have the budget.
The 18-200 vs the f2.8 short zooms is a harder decision. The Nikon 17-55 f2.8 is the pro grade lens, with better low light performance for moving subjects, but far more expensive and far heavier. The 17-55 would probably do you for most shots actually, but you'd need to pair it with the legendary 70-200mm f2.8 VR (again tank-like pro grade), or the excellent 70-300VR if you need more reach. The budget alternative is the Tamron 18-50 f2.8.
As I've said in other threads, the 18-200VR is a great 'swiss army knife' lens. Here are a few applications...
Dull day, handheld at 52mm, 1/15th second (thankyou VR!) , f13 to try and get the path all in focus, 250 ISO
200mm, handheld, 1/350th sec, f7.1, 320 ISO
42mm handheld, 1/15th sec f7.1, 320 ISO
105mm (cropped) handheld 1/2000th sec, f5.6, 640 ISO
200mm handheld, 1/125th sec, f7.1 320 ISO
18mm handheld, 1/8th sec, f3.5, 800 ISO
18mm handheld 1/10th sec, f4, 640 ISO
If it's any help my current lens collection for my D200 is:
Tokina 12-24mm f4
Nikon 18-200VR
Nikon 105VR f2.8 macro
Nikon 50mm f1.8
If I want gorgeously shallow DOF and great bokeh, I have the 50mm, and 105mm, which supplement the 18-200 nicely. The 18-200 has rather scrappy bokeh sometimes, and isn't quite as sharp as the primes. The 50mm is my low light lens when the subject is moving - though too long for some shots. I'm now toying with something longer for wildlife, as 200mm is pushing it (hoping they put VR on the 300mm f4 soon
). I'm also considering either the Nikon 35mm f2 or Sigma 30mm f1.4 to save me spending £750 on the 17-55 f2.8!
Even if you add more specialist glass later, the 18-200VR is a great travel lens when you want to travel light. I find it handy that I've got both wide and tele sorted in one lens, so I can carry that and my macro lens in a smallish shoulder bag.
