flickr to Forum please
Old 18-01-2008, 8:53 PM   #1
goso's Avatar
4,474, Level: 15
Points: 4,474, Level: 15 Points: 4,474, Level: 15 Points: 4,474, Level: 15
Activity: 30.3%
Activity: 30.3% Activity: 30.3% Activity: 30.3%
Thanks: Gave 530, Got 223
I would like to post from flickr to forum is there a post anywhere to help me.
Old 18-01-2008, 8:59 PM   #2
hot-fuzz's Avatar
27,120, Level: 40
Points: 27,120, Level: 40 Points: 27,120, Level: 40 Points: 27,120, Level: 40
Thanks: Gave 372, Got 545
Re: flickr to Forum please
Use the [ img ] http ://www.flickrpictureyougot.jpg [/img ] tags using the
above when making a new post.
Where http ://www.flickrpictureyougot.jpg is the address of your photo on flickr.
goso (19-01-2008)
Old 18-01-2008, 11:22 PM   #3
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Right . . .
Go to you Flickr image and select Image Size (whatever you choose). Underneath is some code. The lower one is what you want (right click and copy).
Go to the AVForums bit you want. Enter your blurb. When you want to enter the image . . click on the INSERT IMAGE icon and paste the link you copied from Flickr. Review before posting. Repeat with all other images you want to copy/paste. I would suggest MEDIUM size.
Send my fee to . . . .
goso (19-01-2008)
