lowepro rezo 160
Old 09-01-2008, 8:41 PM   #1
2,852, Level: 12
Points: 2,852, Level: 12 Points: 2,852, Level: 12 Points: 2,852, Level: 12
Thanks: Gave 26, Got 26
lowepro rezo 160
hi,
possibly a long shot but does anyone have the bag above? and also have a dslr and a zoom lens? i only ask as i am considering buying the above bag for days out (i alreday have the slingshot 200). i have a 400d and want to be able to put that, the kit lens and a 70-300 lens in the bag but can't work out if they will all fit.
thanks for any help
Old 09-01-2008, 8:48 PM   #2
Luffy's Avatar
8,687, Level: 22
Points: 8,687, Level: 22 Points: 8,687, Level: 22 Points: 8,687, Level: 22
Thanks: Gave 111, Got 83
Re: lowepro rezo 160
HI Ive got the rezo 140 and I can get a 350D kit lens and 70-300 in that so you should be ok with the 160
sloth (09-01-2008)
Old 09-01-2008, 10:37 PM   #3
2,852, Level: 12
thanks a lot for your response luffy
Old 10-01-2008, 8:44 AM   #4
mij mij is offline
mij's Avatar
6,580, Level: 19
Points: 6,580, Level: 19 Points: 6,580, Level: 19 Points: 6,580, Level: 19
Thanks: Gave 370, Got 228
I have the Rezo 160 AW and carry a Sony A100 with the 18-70mm kit lens attached along with a Sigma 70-300mm. I still have room for odds & sods as well, a great little bag.
sloth (10-01-2008)
