Sony DSC T20 or Panasonic TZ3?
Old 19-12-2007, 5:00 PM   #1
barrybarryr's Avatar
5,842, Level: 18
Points: 5,842, Level: 18 Points: 5,842, Level: 18 Points: 5,842, Level: 18
Thanks: Gave 38, Got 20
I'm trying to work out what compact camera to buy.
I have seen the TZ3 for £169.99 and the T20 for £134.99 and am trying to decide which one to buy.
Can anyone recommend either of these or a similarly priced alternative?
Barry
Old 20-12-2007, 5:36 PM   #2
5,503, Level: 17
Points: 5,503, Level: 17 Points: 5,503, Level: 17 Points: 5,503, Level: 17
Thanks: Gave 11, Got 7
Re: Sony DSC T20 or Panasonic TZ3?
Originally Posted by barrybarryr View Post
I have seen the for £169.99 and the T20 for £134.99 and am trying to decide which one to buy.
Barry
I recommend Panasonic TZ3, and I'll suggest you to check out the Canon Digital IXUS 860 IS. In terms of size, the camera is very small, yet comfortable in the hand. If you are looking for the best 28 mm point of shoot of it's class, you found it.
Old 20-12-2007, 5:52 PM   #3
5,842, Level: 18
It looks quite nice but is a little expensive, £200 is the cheapest I can find it.
Does anyone have any other suggestions?
