Flickr / Smugmug plugin for Lightroom
Old 03-12-2007, 8:33 PM   #1
5,840, Level: 18
Points: 5,840, Level: 18 Points: 5,840, Level: 18 Points: 5,840, Level: 18
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 148, Got 297
I spotted a reference on John Nack's blog (one of the Lightroom development team) to this site. This guy has used the SDK in Lightroom 1.3 to produce export modules for Flickr, Smugmug and Zenfolio (not familiar with this). Although they're still beta and clearly have some rough edges, I took the link from Nack's blog as a bit of an endorsement and based on some fairly rudimentary testing (Flickr only), I'm quite impressed.
I think I can also fairly safely say, that there is no obvious risk to experiment here - in the worst case, just delete the folder - but form your own judgement and 'caveat emptor'.
electrolyte (03-12-2007)
Old 03-12-2007, 9:16 PM   #2
electrolyte's Avatar
15,316, Level: 29
Points: 15,316, Level: 29 Points: 15,316, Level: 29 Points: 15,316, Level: 29
Thanks: Gave 1,457, Got 1,030
Re: Flickr / Smugmug plugin for Lightroom
This looks cool, thanks for sharing. Perhaps I'm being thick though but how do I get this to work? I've downloaded the flickr plugin folder - where do I put this? I've put it into C:\Program Files\Adobe\Adobe Photoshop Lightroom 1.3\moxplugins - is that the right place?
Old 03-12-2007, 9:28 PM   #3
5,840, Level: 18
Activity: 1.7%
Have a look at the linked site for a good description of how to install.
For me it was C:\documents and settings\username\application data\adobe\lightroom\modules\.....and then drop in the extracted folder. Note that you need to create the 'modules' folder.
Old 03-12-2007, 9:46 PM   #4
15,316, Level: 29
Thanks Colin. It works for me now. And it's excellent; it will save me loads of time.
Old 03-12-2007, 9:50 PM   #5
5,840, Level: 18
Activity: 1.7%
Good stuff . I'm certainly quite impressed.
Old 15-02-2008, 11:31 PM   #6
Steven's Avatar
61,737, Level: 60
Points: 61,737, Level: 60 Points: 61,737, Level: 60 Points: 61,737, Level: 60
Activity: 37.5%
Activity: 37.5% Activity: 37.5% Activity: 37.5%
Thanks: Gave 2,014, Got 4,411
Not working for me
Can't authenticate. And not sure how to authenticate on flickr?
Flickr / Smugmug plugin for Lightroom-untitled.jpg
Old 16-02-2008, 7:46 AM   #7
hot-fuzz's Avatar
27,120, Level: 40
Points: 27,120, Level: 40 Points: 27,120, Level: 40 Points: 27,120, Level: 40
Thanks: Gave 372, Got 545
This might be a good alternative.
I currently use Lightroom to edit my photos in RAW, then once i have done what i needed to them i export them to my "gallery" on my HD.
I also have PIcassa up and running and it detects the new photo almost instantly.
So then when i have adited all my photos i can bulk upload them to Smugmug through the Smugmug addon in Picassa.
