First time in a studio!
Old 03-12-2007, 11:43 AM   #1
weaviemx5's Avatar
4,368, Level: 15
Points: 4,368, Level: 15 Points: 4,368, Level: 15 Points: 4,368, Level: 15
Thanks: Gave 359, Got 94
Hi Guys,
I spent 2 hours at the Matchworks Studio in Liverpool with a friend of mine yesterday afternoon. I've got to say that I loved it and it was a real change from my usual landscape shots...especially chasing a 10 month old with a 50mm prime lens!
I've attached a couple of the shots for feedback/suggestions.
1) Just Chilling...
2) Smiler! (small amount of soft focus added)
3) Lounging
These are all clickable back to my Flickr Set where there are a few more pictures.
Steve
Old 03-12-2007, 11:46 AM   #2
5,201, Level: 17
Points: 5,201, Level: 17 Points: 5,201, Level: 17 Points: 5,201, Level: 17
Thanks: Gave 62, Got 106
Re: First time in a studio!
Great shots, I like the first one - the slight shadow works really well.
Second one seems a little bright but that may just be due to the forum background being white too
weaviemx5 (03-12-2007)
Old 03-12-2007, 11:59 AM   #3
weaviemx5's Avatar
4,368, Level: 15
Thanks. The 2nd shot is a bit more over-exposed as I was trying out different settings to blow out the backdrop but keep detail in the shot. I think the 'soft-focus' effect makes the image look a bit brighter as well.
Steve
