Cigarette paper to clean
Old 22-11-2007, 11:17 PM   #1
BananaTiger's Avatar
4,878, Level: 16
Points: 4,878, Level: 16 Points: 4,878, Level: 16 Points: 4,878, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 47, Got 127
Right, I was watching a video podcast with some photography tips and this guy was talking about stuff he brings in his kit bag for his travels. He mentioned that he used cigarette paper (the ones for rollies like Rizla) as a cheap throwaway solution to wipe on the front element of your lens to clean grease and dirt - very much like those papers you see some girls use to wipe away oils on thier faces. Anyone used this trick before? Sounds wierd but the guy seems to know his stuff.
Old 23-11-2007, 9:18 AM   #2
jonnypb's Avatar
13,765, Level: 28
Points: 13,765, Level: 28 Points: 13,765, Level: 28 Points: 13,765, Level: 28
Thanks: Gave 319, Got 590
Re: Cigarette paper to clean
i'd have thought they were a bit too harsh to use on a lens and would be more use as a diffuser on a flash
Old 23-11-2007, 9:31 AM   #3
4,878, Level: 16
Activity: 0.8%
Not being a smoker, I'm not sure what the texture of the paper is like. And considering how cheap they are, I'm a bit sceptical too. But he did wipe his L-lens with one of them on the video
Old 23-11-2007, 10:10 AM   #4
bodoman's Avatar
13,445, Level: 27
Points: 13,445, Level: 27 Points: 13,445, Level: 27 Points: 13,445, Level: 27
Thanks: Gave 1,165, Got 1,306
I would not think it a good idea as a rizla has a strip of gum on it
Old 23-11-2007, 10:43 AM   #5
Liquid101's Avatar
15,145, Level: 29
Points: 15,145, Level: 29 Points: 15,145, Level: 29 Points: 15,145, Level: 29
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 599, Got 1,489
I have a packet of King Size here, i'll give it a go.
Old 23-11-2007, 10:49 AM   #6
bodoman's Avatar
13,445, Level: 27
They will do a spliffing job
Old 23-11-2007, 11:13 AM   #7
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
I've got a lens cleaning kit that includes some thin paper wipes, a bit like fag papers.
You basically drop some cleaning fluid on the lens element and use the wipes to push it around until it evaporates and any dirt ends up on the paper.
I guess using just a fag paper is a trick for when you're out and there's nothing else to use. I can't see it doing any harm as long as it's kept the right way up.
Old 23-11-2007, 11:21 AM   #8
4,878, Level: 16
Activity: 0.8%
Maybe there are brands that don't have the gum bits? His one seemed to be some no-branded ones.
Here's a link to the video (mp4 format)
http://www.tipsfromthetopfloor.com/2...king-the-bags/
