| Re: What should i look for in a camera?
to be honest mate the optical viewfinder is rubbish on most compacts, the paralax errors make framing your shots pointless. The screen on the LX2 allows you to boost the brightness and colours for viewing at greater angles (above your head) so performs really well in bright sunlight... Also it still has to display info on shutter speeds and apertures, blown hightlights, histogram etc... which you get none of in a viewfinder.
I have the LX2 and i love it to bits.. although its very noisy in low light and at high ISO's but on things like night landscapes and stuff it doesnt really matter as you can keep the iso low and expose for longer.
Obviously you can get bigger zooms on the smaller bodies now so its a case of what your needs are.. personally i dont need a big zoom on a compact. I have an SLR for that. The LX2 has been out for over a year now and i think is due to be replaced come spring time next year so be wary of that.. Panasonic have produced new image processing software on thier newer models so i would expect the LX3 (probably) to have that on it.. which would solve many of the noise issues
