Sony Memory Stick Duo cards.. whats the difference?
Old 14-11-2007, 1:06 PM   #1
4,821, Level: 16
Points: 4,821, Level: 16 Points: 4,821, Level: 16 Points: 4,821, Level: 16
Thanks: Gave 2, Got 1
Question Sony Memory Stick Duo cards.. whats the difference?
Im a bit confused.... im looking at buying a new sony t200 digital camera and i need to buy a memory card, looking at atleast 4gb. I have 2 ways of doing it..
1] Buy a Sony 4GB Memory Stick Duo Pro at £34.99
or
2] Buy 2x Sony 2GB Memory Stick Duo Pro Hi-Speed for £40 in totoal.
Is one better than the other or they both the same? and whats differnece in the Memory Stick Duo Pro Hi-Speed and the Memory Stick Duo Pro??
help.
Old 14-11-2007, 1:16 PM   #2
Conspicuous Member
pixelpixel's Avatar
24,046, Level: 37
Points: 24,046, Level: 37 Points: 24,046, Level: 37 Points: 24,046, Level: 37
Activity: 36.4%
Activity: 36.4% Activity: 36.4% Activity: 36.4%
Thanks: Gave 1,618, Got 1,181
Re: Sony Memory Stick Duo cards.. whats the difference?
I have a 1 gig and a 4 gig SanDisk all basic models and no problems with them.
Old 14-11-2007, 4:17 PM   #3
4,821, Level: 16
but is there any difference between Sony Memory Stick Duo Pro and Sony Memory Stick Duo Pro Hi-Speed?
Old 14-11-2007, 4:38 PM   #4
Conspicuous Member
pixelpixel's Avatar
24,046, Level: 37
Activity: 36.4%
Just the price, never used a Hi-Speed card no need for it. IMO.
Old 14-11-2007, 6:05 PM   #5
18,290, Level: 32
Points: 18,290, Level: 32 Points: 18,290, Level: 32 Points: 18,290, Level: 32
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 119, Got 135
I think the High Speed card has actually just been replaced by something else.
I use the standard cards in my CX6 HD camcorder. If they are fast enough for this, they must be fine for a standard cam.
4GB cards are £30 at Play and Amazon.
Old 14-11-2007, 6:05 PM   #6
18,290, Level: 32
Activity: 5.7%
