I need a very basic, idiot proof digi camera
Old 06-11-2007, 11:43 AM   #1
THE AMATUER's Avatar
10,364, Level: 24
Points: 10,364, Level: 24 Points: 10,364, Level: 24 Points: 10,364, Level: 24
Activity: 5.4%
Activity: 5.4% Activity: 5.4% Activity: 5.4%
Thanks: Gave 108, Got 123
I want to buy my mum her first digital camera for xmas. She is a complete technophobe so I need a camera thats very easy to use.
I only want to spend upto £100 as she will only be using it for family pics and general use, she certainly doesn't need any fancy functions on it.
Any ideas please?
Old 06-11-2007, 11:49 AM   #2
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
Re: I need a very basic, idiot proof digi camera
#I hope she doesn't use the 'net or you might not be getting anything in return...
Most compact point and shoot cameras are simple enough to use, you just point and shoot!
THE AMATUER (06-11-2007)
Old 06-11-2007, 11:50 AM   #3
10,180, Level: 24
Points: 10,180, Level: 24 Points: 10,180, Level: 24 Points: 10,180, Level: 24
Thanks: Gave 316, Got 221
A few months ago I needed to buy a similar specced camera for my dad. In the end I went for a Fuji F31fd. Looking on the web it seems that the successor (I'm assuming it's the successor) is just out of your budget on Amazon.
http://www.amazon.co.uk/Fuji-FinePix...4349642&sr=8-3
I choose the F31fd as firstly it was meant to be easy to use, and secondly I liked the sound of its very good low light performance. I decided that my dad would be more likely to be able to take shots inside and them not come out blurred.
From the looks of things the F31fd seems to be more expensive than it's successor though, so maybe there's a reason for that... Not sure?
I'm not sure if that helps...
Old 06-11-2007, 11:59 AM   #4
10,364, Level: 24
Activity: 5.4%
:-) I didn't mean it to sound like my mums an idiot because shes not....but when it comes to anything technical she struggles... (sorry mum !!)
Old 06-11-2007, 12:04 PM   #5
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
Here are some camera reviews that may help.
Remember, go for optical not digital zoom, all digital zoom does is degrade the picture quality.
I would still recommend having a optical view finder as this helps when things get really dark or in bright sunlight.
http://www.steves-digicams.com/best_cameras.html
Most are beyond the £100 mark but there are loads of reviews at the bottom of the page.
Good luck.
Old 06-11-2007, 12:11 PM   #6
4,510, Level: 15
Points: 4,510, Level: 15 Points: 4,510, Level: 15 Points: 4,510, Level: 15
Thanks: Gave 16, Got 146
THis may be more than suitable.
http://www.argos.co.uk/webapp/wcs/st...&storeId=10001
Old 06-11-2007, 12:18 PM   #7
10,364, Level: 24
Activity: 5.4%
Originally Posted by Para View Post
Ha ha ha...that made my laugh mate.....off to Argos I go although I still think she will struggle with that one :-)
Old 06-11-2007, 12:39 PM   #8
4,510, Level: 15
Sorry, couldn't help myself.
Always found connons really easy to use. My folks have to if that helps. Their auto settings are great!
Old 06-11-2007, 12:42 PM   #9
6,798, Level: 19
Points: 6,798, Level: 19 Points: 6,798, Level: 19 Points: 6,798, Level: 19
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 97, Got 139
the bigger problem you need to think about is not a camera that takes photos easily but who's gonna deal with getting them off the camera, printed and backed up
Can boots etc print a memory cad and give you a cd backup at the same time now ?
Old 06-11-2007, 12:48 PM   #10
4,510, Level: 15
Yeah they can, or snappy snaps or other simlar places..
Old 06-11-2007, 12:50 PM   #11
6,798, Level: 19
Activity: 1.8%
that's good if they can't use a PC
Old 06-11-2007, 12:51 PM   #12
4,762, Level: 16
Points: 4,762, Level: 16 Points: 4,762, Level: 16 Points: 4,762, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 44, Got 56
How many megapixels is that?
dpstjp
