A couple from tonight
Old 29-10-2007, 7:18 PM   #1
Luffy's Avatar
8,687, Level: 22
Points: 8,687, Level: 22 Points: 8,687, Level: 22 Points: 8,687, Level: 22
Thanks: Gave 111, Got 83
After yesterdays disaster l decided to try and grab tonights sunset
I think I should have used filling flash for the fore ground
I've tweeked the curves a little but thats all
C & C welcome
Old 29-10-2007, 8:06 PM   #2
tontoshorse's Avatar
12,395, Level: 26
Points: 12,395, Level: 26 Points: 12,395, Level: 26 Points: 12,395, Level: 26
Thanks: Gave 775, Got 693
Re: A couple from tonight
Have you tried a bit of sharpening?
Luffy (29-10-2007)
Old 29-10-2007, 8:15 PM   #3
Luffy's Avatar
8,687, Level: 22
not yet will give it a go thanks
Old 29-10-2007, 8:27 PM   #4
12,395, Level: 26
A neat trick I was shown for sharpening is:
Layer, new, by copy.
Overlay (at 100% opacity)
Filter, other, high pass.
use the slider so as to sharpen but not give halos.
works a treat.
I was extremely grateful for that advice.
Old 29-10-2007, 8:27 PM   #5
Luffy's Avatar
8,687, Level: 22
Used an unsharp mask is that the best way?
Best try again ta
Old 29-10-2007, 8:33 PM   #6
12,395, Level: 26
Best try again ta
I found usm gave nasty great halos and big black lines.
Old 29-10-2007, 8:41 PM   #7
Luffy's Avatar
8,687, Level: 22
Mark3
thanks
Old 29-10-2007, 8:43 PM   #8
12,395, Level: 26
I know its "not the done thing", but I couldn't resist editing your original, just to show you the difference in sharpening techniques. Hope you don't mind.
Still a bit of a halo at the top though lol.
Old 29-10-2007, 8:54 PM   #9
Luffy's Avatar
8,687, Level: 22
No problem feel free thanks I'm not precious about them
Old 31-10-2007, 7:47 AM   #10
6,551, Level: 19
Points: 6,551, Level: 19 Points: 6,551, Level: 19 Points: 6,551, Level: 19
Thanks: Gave 140, Got 99
Thanks for that technique Scout (Tontos Horse), I have now set it up as an ‘Action’ on my PS, it works a lot better than Unsharpen Mask, as you say ‘No Halo’.
