new camera help?
Old 29-10-2007, 1:01 PM   #1
gunner84's Avatar
6,837, Level: 19
Points: 6,837, Level: 19 Points: 6,837, Level: 19 Points: 6,837, Level: 19
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 126, Got 21
new camera help?
hi
im looking for a new digital compact camera for a beginner.
and ive narrowed it down to the panasonic lumix tz3 and the cannon powershot g9,
both cameras seem to have good ratings and i like the fact the g9 has a viewfinder , now the g9 is a bit more expensive but im swaying towards it, has anyone got any advice on these?
cheers
Old 29-10-2007, 1:04 PM   #2
Conspicuous Member
21,526, Level: 35
Points: 21,526, Level: 35 Points: 21,526, Level: 35 Points: 21,526, Level: 35
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 4, Got 1,393
Re: new camera help?
Here is an excellent site http://www.steves-digicams.com/best_cameras.html with the G9 showing as top of the pops in its category.
gunner84 (29-10-2007)
Old 29-10-2007, 5:56 PM   #3
6,798, Level: 19
Points: 6,798, Level: 19 Points: 6,798, Level: 19 Points: 6,798, Level: 19
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 97, Got 139
Well I own the G9 so I'm probably biased
If you want a camera that has good zoom range then TZ3 is better with 28-280mm. G9 only has 35-210.
G9 wins on image quality, raw, controls, build quality, hot shoe (430EX can make a massive difference to shots in doors.)
have a read of the reviews at dpreview.com G9 one only came out on Friday
Old 29-10-2007, 6:57 PM   #4
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Thanks: Gave 523, Got 1,253
Ahoy!
Toughie . . for a beginner you say . . . tougher still. Many have the TZ3 on this forum. For a beginner . . . I guess there's a learning process or just put it into AUTO mode (which can be hit-and-miss at the best of times).
TZ3 has image stabilisation too and 10x optical zoom, though I would thoroughly research both and try and get 'hands-on' before deciding.
