Dirt through the viewfinder, but not on images
Old 15-10-2007, 11:37 AM   #1
7,350, Level: 20
Points: 7,350, Level: 20 Points: 7,350, Level: 20 Points: 7,350, Level: 20
Thanks: Gave 100, Got 70
Question Dirt through the viewfinder, but not on images
I have just noticed a speck of dirt / dust when looking through the viewfinder of my 40D. Thing is, it does not appear on any images - even an image of white paper @ f32.
It's not lens specific and I have cleaned the viewfinder eyepiece.
I'm not using the dust map (Dust Delete Data) feature of the 40D either.
Any ideas / suggestions?
Gary
Old 15-10-2007, 11:39 AM   #2
Paranormalist's Avatar
10,827, Level: 24
Points: 10,827, Level: 24 Points: 10,827, Level: 24 Points: 10,827, Level: 24
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
Thanks: Gave 1,339, Got 622
Re: Dirt through the viewfinder, but not on images
If I'm not mistaken I've read about somebody else on here having the same issue with the 40D. Can't remember who it was though.
Sorry I can't be of more help.
Old 15-10-2007, 11:43 AM   #3
10,827, Level: 24
Activity: 3.1%
I've found the thread.
Canon 40D Minor Fault , Advice Appreciated
GaryK26 (15-10-2007)
Old 15-10-2007, 11:45 AM   #4
12,951, Level: 27
Points: 12,951, Level: 27 Points: 12,951, Level: 27 Points: 12,951, Level: 27
Thanks: Gave 36, Got 547
If it's sharply in focus it's probably on the focussing screen (the screen above the mirror). If it's blurry, it's probably on the mirror. A blower should shift it in either case (be careful not to touch either screen or mirror though).
Gunk on the focussing screen is a perennial problem though, and if it's not too distracting, it's probably not worth bothering with.
Old 15-10-2007, 11:51 AM   #5
7,350, Level: 20
IQ is not affected in any way whatsoever.
It's just annoying - especially as I've only had the camera for 2 weeks.
I tried a rocket blower yesterday - at the sensor though as that was before I had deduced that it probably wasn't the sensor. Not sure whether to just leave it as is (as suggested) or to maybe give the inside a good blow with the mirror down.
Old 15-10-2007, 12:49 PM   #6
4,593, Level: 16
Points: 4,593, Level: 16 Points: 4,593, Level: 16 Points: 4,593, Level: 16
Thanks: Gave 63, Got 30
not sure how much help it will be for a viewfinder but maybe
LINK
we use them for sensor cleaning and they are excellent
Old 15-10-2007, 12:57 PM   #7
Liquid101's Avatar
15,140, Level: 29
Points: 15,140, Level: 29 Points: 15,140, Level: 29 Points: 15,140, Level: 29
Activity: 10.6%
Activity: 10.6% Activity: 10.6% Activity: 10.6%
Thanks: Gave 596, Got 1,488
It's either on the mirror, or more likely on the ground glass screen directly above. Either way, a direct blow with a rocket should shift it.
