does the IR remote for the 350d work on the 30D/40D?
Old 17-09-2007, 6:24 PM   #1
45,524, Level: 52
Points: 45,524, Level: 52 Points: 45,524, Level: 52 Points: 45,524, Level: 52
Activity: 20.3%
Activity: 20.3% Activity: 20.3% Activity: 20.3%
Thanks: Gave 378, Got 854
selling my 350d to get a 40D (on the non-AV sales forum now, go look - great price!).
But I want a remote release for it. I already have the IR release for the 350d. Does anyone know if that works on the 30D/40D?
If not then I'll chuck it into the bundle to sweeten it.
If it doesn't, then whats the cheapest remote release? Ideally IR but wired would be ok
Old 17-09-2007, 6:57 PM   #2
Conspicuous Member
Crocodile's Avatar
15,124, Level: 29
Points: 15,124, Level: 29 Points: 15,124, Level: 29 Points: 15,124, Level: 29
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 408, Got 1,147
Re: does the IR remote for the 350d work on the 30D/40D?
30D doesn't have an IR receiver so I doubt (but haven't checked) that the 40D has one.
I've just bought a 3rd party cable release for my 30D for £9 delivered. The official Canon RS-80N3 is ridiculously expensive for a short piece of wire, a switch & Canon's fancy proprietary N3 connector.
Old 17-09-2007, 7:03 PM   #3
atr1981's Avatar
5,147, Level: 16
Points: 5,147, Level: 16 Points: 5,147, Level: 16 Points: 5,147, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 10, Got 39
Could you expand on where you got it ?
I'm looking for one too. Did you get the extension cable ?
Old 17-09-2007, 7:21 PM   #4
Conspicuous Member
Crocodile's Avatar
15,124, Level: 29
Activity: 11.8%
Forum member Wbessada sells them & other accessories on other forums. I guess a direct link would be frowned upon so try dropping him (or me) a PM. Think I had the last of his current stock though.
Edit
There's some interesting mods out there that involve chopping the standard cable in half & fitting PS2 connectors to enable cheapo keyboard extension cables to be used.
Old 17-09-2007, 9:23 PM   #5
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
The 350/400D remote does not work as explained above and Canon are really being greedy ( OK capitalist...) with the 30/40D model given its "basicness"
Old 17-09-2007, 9:49 PM   #6
45,524, Level: 52
Activity: 20.3%
thanks. Didn't like the idea of the cable remote not being very long, but I need something. Still, get rid of this and get something else..
