UV Filters
Old 22-06-2007, 3:16 PM   #1
fuzed's Avatar
4,034, Level: 14
Points: 4,034, Level: 14 Points: 4,034, Level: 14 Points: 4,034, Level: 14
Thanks: Gave 8, Got 19
UV Filters
what do you guys think in regards to these, I've got a new 17-55 f/2.8 IS canon lens and need a UV filter for it, theres so many to choose from I don't know whether it would be worth spending a little more and getting a good one or a cheaper one will do the same job, has anyone ever done any reviews on these things?
(its a 77mm one I need, if anyone's got a spare knocking around let me know)
cheersssss
Old 22-06-2007, 3:44 PM   #2
h4rri's Avatar
7,667, Level: 20
Points: 7,667, Level: 20 Points: 7,667, Level: 20 Points: 7,667, Level: 20
Thanks: Gave 37, Got 173
Re: UV Filters
You can get a Hoya Pro for £25 off eBay and to be honest it's not worth bothering with the cheap ones. I probably do have a spare Jessops 77mm knocking about but as it drops at least one stop when added I would be reluctant to hand it over
After seeing the results of cheap ones next to the better ones I wouldn't go back. You have an expensive bit of glass so stick the best you can afford on it
Old 22-06-2007, 4:08 PM   #3
fuzed's Avatar
4,034, Level: 14
Re: UV Filters
cheers harri... thats what I needed to know... The hoya pro's a good one then, I have a few hoya filters, shame I dont have any that fit!
Old 22-06-2007, 4:39 PM   #4
8,837, Level: 22
Points: 8,837, Level: 22 Points: 8,837, Level: 22 Points: 8,837, Level: 22
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 251, Got 370
Re: UV Filters
Ditto, on the avoiding the cheapo ones. I have a cheapo Jessops uv filter and it's a shoddy piece of plastic that's a bugger to keep clean. The polarizer I use is a good quality Hoya Pro and is vastly superior. www.onestop-digital.com have really good filter prices.
Old 22-06-2007, 5:22 PM   #5
fuzed's Avatar
4,034, Level: 14
Re: UV Filters
cheers guys, so you'd all consider the hoya to be a good filter... any others to think of or stick to this one?
Old 22-06-2007, 5:39 PM   #6
grantsteve's Avatar
5,435, Level: 17
Points: 5,435, Level: 17 Points: 5,435, Level: 17 Points: 5,435, Level: 17
Thanks: Gave 339, Got 212
Re: UV Filters
B+W are highly regarded, as are Lee .... if you've got the cash!
I'm a Hoya Pro fan myself. One Stop Digital are the best value I've found and they'll deliver nearly as quick as most UK stockists.
Old 22-06-2007, 5:50 PM   #7
6,942, Level: 19
Points: 6,942, Level: 19 Points: 6,942, Level: 19 Points: 6,942, Level: 19
Thanks: Gave 8, Got 57
Re: UV Filters
Or if you wanna try a cheapy and see how it is, you could get a HAMA one for about 6 quid off peebay. If it's no good just relist it.
Old 22-06-2007, 6:36 PM   #8
20,666, Level: 34
Points: 20,666, Level: 34 Points: 20,666, Level: 34 Points: 20,666, Level: 34
Activity: 12.1%
Activity: 12.1% Activity: 12.1% Activity: 12.1%
Thanks: Gave 105, Got 467
Re: UV Filters
Another vote for the Hoya Digital Pro 1 UV.
I have two and apart from the difficulty in cleaning them they are very high quality.
got both mine from onestop but picstop.co.uk have them for £43 which i think is a bit cheaper than some uk places.
And dont forget to get a hood. and get it off ebay not from a shop. You can pick up the Canon one for around £20 off ebay. May or may not be genuine but i cant tell the difference.
Old 22-06-2007, 6:58 PM   #9
allymac123's Avatar
9,729, Level: 23
Points: 9,729, Level: 23 Points: 9,729, Level: 23 Points: 9,729, Level: 23
Thanks: Gave 489, Got 451
Re: UV Filters
I'd personally recommend a hood over a UV filter. Personally (and in a few personal experinces) the hood does a better job at protecting the lens as whole. It also has the added benefit of stopping stray light entering the lens.
My experience was when I had my camera ~6ft high on a tripod above some rocks and then I managed to kick the tripod (don't ask). This sent the camera with 17-55 F2.8 IS attached straight for the ground. The lens hood bent, as that is what it landed on, and thus absorbed a major propotion of the imapct and everything was fine and dandy. (thank f***, although I do have it all fully insured). I was also shooting with a ND8 filter on at the time (not a scratch on it) but I do believe had I been without the lens hood the entire combo would likely be broken.
Double protection is probably best but remember a lens hood can't be detremental to pic quality but putting any glass infront of a lens will cause a change.
Old 22-06-2007, 7:10 PM   #10
fuzed's Avatar
4,034, Level: 14
Re: UV Filters
I didn't think about the lens hood... could be a better option, I'm just wanting to try and keep the lens clean and safe, thankyou all
Old 22-06-2007, 7:56 PM   #11
20,666, Level: 34
Activity: 12.1%
Re: UV Filters
This lens suffers a bit more from flare than some other lens's (like the Tamron 17-50 f/2.8) so a hood is very useful.
I would still get a filter just to be safe in bad weather etc. My take on this is that while im sure i wont get the front element scratched i may damage it when im cleaning it. I feel nervous cleaning a front element but not cleaning a lens.
And so far ive not seen any IQ problems due to using a filter.
