Damselfly Kama Sutra
Old 03-06-2007, 8:32 AM   #1
jomike's Avatar
9,090, Level: 22
Points: 9,090, Level: 22 Points: 9,090, Level: 22 Points: 9,090, Level: 22
Thanks: Gave 461, Got 377
First clasp your partner around the neck with your abdominal claspers.
Then have her bring her abdomen around to meet your working parts. This is called the Hula Hoop position.
Mike
Old 03-06-2007, 8:53 AM   #2
SweetGirl's Avatar
7,946, Level: 21
Points: 7,946, Level: 21 Points: 7,946, Level: 21 Points: 7,946, Level: 21
Thanks: Gave 518, Got 340
Re: Damselfly Kama Sutra
I took a few shots of Damselfly yesterday.
Very beautiful insects.
So much detail in their wings. Post later on.
I like the 2nd one best- Hula Hoop position.
Interesting position...
Is it the female or male that has to kill her back to please their partner?
Old 03-06-2007, 9:28 AM   #3
13,799, Level: 28
Points: 13,799, Level: 28 Points: 13,799, Level: 28 Points: 13,799, Level: 28
Thanks: Gave 536, Got 296
Fantastic shots Mike
I checked out the original on flickr and the detail is excellent.
I see you used a 90m lens, which one was it please.
Old 03-06-2007, 9:40 AM   #4
jomike's Avatar
9,090, Level: 22
Thanks Sweetgirl and Steve.
The male is the more colourful blue one. No changes there then.
The lens was a Tamron 90mm Macro
Mike
Steve N (03-06-2007)
Old 03-06-2007, 9:54 AM   #5
16,655, Level: 31
Points: 16,655, Level: 31 Points: 16,655, Level: 31 Points: 16,655, Level: 31
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,218, Got 968
Hi ya
Great capture there . Really do like the look of this lens, could be my next buy.
One question, how far away was you from the Damselfly was you ?
Cheers Holo
Old 03-06-2007, 10:56 AM   #6
jomike's Avatar
9,090, Level: 22
Thanks Holo, I was about 2-3ft away in the first one, about 6-8in in the second. The bugs have to be fairly cooperative at this focal length. The really serious bug shooters usually use 150mm + lenses, but this is out of my price range. You can also increase working distance with diopters and/or teleconverters, and increase magnification and reduce working distance with tubes.
If you do decide to get this lens, you won't be sorry. The AF is as noisy and slow as they say, but for bugs you usually use MF. The sharpness is a real eye opener, and it is good VFM as far as macro lenses go IMO. I paid £200 for mine off Onestop Digital
Mike
Holowlegs (03-06-2007)
Old 03-06-2007, 11:32 AM   #7
Gizmo 76's Avatar
8,391, Level: 21
Points: 8,391, Level: 21 Points: 8,391, Level: 21 Points: 8,391, Level: 21
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 261, Got 402
No. 2 for me, shame you clipped the wing, but I know how damn tricky this macro lark is, still a cracking shot
Old 03-06-2007, 11:41 AM   #8
jomike's Avatar
9,090, Level: 22
Thanks Gizmo.
Sod's law, I got some with the whole wing in frame, but the focus wasn't as sharp.
Miike
Old 04-06-2007, 11:44 AM   #9
5,345, Level: 17
Points: 5,345, Level: 17 Points: 5,345, Level: 17 Points: 5,345, Level: 17
Thanks: Gave 355, Got 215
Both are excellent photographs Mike.
Their bodies make the shape of a heart (Ish!). Ah, true love.
Cheers.
jomike (04-06-2007)
