| Re: Being made redundant lots of advice please
I can't fault the bulk of your lens choice but I would question the need for the 100mm macro and the 400mm for weddings. What I would definitely say though is buy a second body and a second speedlite! This is for two reasons.
1. If your camera fails then you are REALLY in trouble and looking at the wrong end of a law suit.
2. With all those lenses you are going to be changing lenses all the time and will just end up missing shots.
Other kit to consider, which you may already own.
1. A good tripod with a geared center column and a good ball head. A geared column will allow you to adjust the height of the camera quickly, accurately and quietly
2. Reflectors. If you arent going to have an assistant than buy the Lastolite ones with the handle so that you can hold it with one hand and the camera in the other.
3. Don't buy a rucksack! Well that's my opinion anyway. Rucksacks are great for walking but pretty crap for when you often need to get gear out of it. I shot a couple of weddings with a rucksack and never again. I now use a shoulder bag and the difference is significant, I can leave it open without gear falling out, I don't have to take it off to get at my gear and I can hold a lot more gear in my Magnum AW than I can in my Slingshot 300 AW.
4. Buy a cable release for group shots. Chuck the camera on a tripod, compose the scene and then use the cable release. This way you can engage everyone in the group, see more clearly where everyone is looking and also people won't be aware of when you take the photo so you won't get as many forced smiles etc.
5. Some kind of digital wallet to download your cards to. You should always take enough cards to shoot an entire wedding without the need to download them but for security I would always make a copy of them just in case you loose a card or a card dies on you.
6. Other than equipment make sure you get professional indemnity and public liability insurance as well as camera insurance.
HTH
