Originally Posted by Keyman Most of my photos are family shots/snaps and now starting to find maybe the onboard flash is a bit too harsh and maybe because of the dim lighting at home, the background can be relatively dark too. Maybe external flash is the answer. |
Maybe. The reason for the dark background is that the light from the flash is falling off after a certain distance. This is something you will encounter with all flash guns as the only light source that can avoid producing this at all distances is the sun. That said the more powerful the flash gun the further you can be from yoru subject and the further your subject can be from the background before you see the light falling off in this way. The power of the flash gun is measured by the guide number, the higher the number the more powerful it is.
Searched through a few posts and kind of narrow it down to a few flash. Sigma 500 ST or Super, 430ex or 580ex. Being a mid class working family man, I do not want to overspend, but if it got be to the big bucks 580ex, so be it.
Originally Posted by Keyman The question in simple term is, which is best flash for home snaps under the following circumstances. |
Hmm, not really the correct question to ask as the best flash gun in any situation will generally be the best flash gun that you can buy, which in the models you mentioned, is the 580EX. Instead the question I think you meant to ask is "Do I have to buy the 580EX or will a 'lesser' flash gun suit my needs under the following circumstances?"
Originally Posted by Keyman 1. Beginer photographer, the easier to use, the better. |
Hmm, this isn't as straight forward as you would think it would be. Ultimately any flash gun can just be whacked on the hotshoe and set to Auto and will then behave just like the on board flash, just better quality light. The easiest to use flash guns are those that don't offer much in the way of other features or have much in the way of manual controls. However all the flash guns you list have a range of features and manual controls so there isn't really much to seperate them in this regard
Originally Posted by Keyman 2. Want to achieve reasonable quality, is the bigger flash also a reason for a better photo, i.e. allow faster exposure (one year old daughter here) and brighter overall (background). |
More powerful flash doesnt mean faster shutter speeds. The max shutter speed with ANY flash gun is determined by the x-sync speed of your camera which is generally 1/125th of 1/250th. This is the maximum shutter speed you can use with the flash under normal circumstances. Many flash guns also have a mode called FP or Focal Plane which allows you to use any shutter speed beyond the x-sync speed. The way this works is by strobbing the flash but it also means that you don't get the full power of the flash and so the light will fall off sooner resulting in the black backgrounds. To answer you question the choice of speedlite will be determined by the size of room you shoot in, how far away you are from your subject, how dark the room is and how far the subject is from the background. The 430EX has the lowest guide number of those you listed and so won't be as flexible as any of the others so I personally would look at either of the Sigmas or the 580EX.
Originally Posted by Keyman 3. Can I get away with the cheaper flash, does the auto setting work well, all that stuf to do with TTL metering? (absolute newbie here) |
Yes you can get away with the cheapest flash, especially as the Sigma is actually a nice flash gun and more powerful than the 430EX. The auto settings do work well especially if you use Aperture Priority or Shutter Priority modes on your camera. In these modes the camera will meter the scene and if there is enough light it will only use the flash as a fill light, if the scene is too dark it will use the flash as the main light source - this is one of the aspects of TTL metering. TTL metering is pretty complex but thankfully you don't need to know too much about it if you don't want to but basically one of the things it does it measures how far the subject is from the camera (based on focal length and where you are focused to) and works out what the correct exposure should be for it.
Originally Posted by Keyman 4. Is there a particular one easier to use with bouncer or diffuser under auto or easy to use settings. |
Nope. All are dead simple and the same. Simply angle the head to bounce it or chuck on a diffuser and that's it.
I own the Sigma EF 500 Super DG which has served me very well and is just as good as the 'old' 550EX. Admittedly the 580EX is better than the Sigma but for your needs I really see no point in paying £350 when £150 will buy you a very, very nice flash gun. I personally would buy the Super version over the Standard version simply because the Super is that bit more versatile and a £150 is such a small amount to pay for a flash gun that offers all it does. However the Standard one at £100 would also suit your needs perfectly so it's up to you really which you get.
HTH
