Best memory for Sony A100
Old 11-04-2007, 12:11 PM   #1
3,895, Level: 14
Points: 3,895, Level: 14 Points: 3,895, Level: 14 Points: 3,895, Level: 14
Thanks: Gave 4, Got 0
Hi all
Just bought a Sony a100 SLR, and I notice that it takes CF memory as well as Sony's Memory Stick Duo.
Question is - from a write speed perspective, is one memory type better than the other?
thanks!
Old 11-04-2007, 1:09 PM   #2
18,302, Level: 32
Points: 18,302, Level: 32 Points: 18,302, Level: 32 Points: 18,302, Level: 32
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Thanks: Gave 119, Got 135
Re: Best memory for Sony A100
I would have though that a good CF card would easily outstrip Sony MS Duo for speed. You will only notice it once the camera buffer fills up, though.
Good CF cards are quite cheap now at about £30 for 4GB of Sandisk Ultra II memory. It may not be worth going to CF if you have loads of Duo cards, or loads of other devices that could utilise your cards.
I have a Canon 400D, and use an SD to CF converter (similar to the Duo to CF one included with the A100), as I have a lot of SD memory. I have some Sandisk Extreme III CF cards as well now - these are faster than the SD cards, but not always noticeable in everyday use.
Matty (11-04-2007)
Old 11-04-2007, 1:30 PM   #3
3,895, Level: 14
thanks for that - I've bought a couple of CF cards and will see how I get on!
