Camera playing up
Old 10-04-2007, 7:24 PM   #1
3,849, Level: 14
Points: 3,849, Level: 14 Points: 3,849, Level: 14 Points: 3,849, Level: 14
Camera playing up
Anyone any ideas whats going on with this camera
Old 10-04-2007, 10:11 PM   #2
denno75uk's Avatar
6,544, Level: 19
Points: 6,544, Level: 19 Points: 6,544, Level: 19 Points: 6,544, Level: 19
Thanks: Gave 310, Got 585
Re: Camera playing up
It's tripping .
Seriously though, I've no idea. Seems pretty terminal though doesn't it? Could be metering issue as the sensor is capturing some data in lower light areas.
Old 10-04-2007, 10:16 PM   #3
18,426, Level: 32
Points: 18,426, Level: 32 Points: 18,426, Level: 32 Points: 18,426, Level: 32
Thanks: Gave 310, Got 933
Wow - that's not right at all. I've no idea what it is but it looks seriously bad. What make/model etc and how long have you had it?
Old 10-04-2007, 10:39 PM   #4
2,858, Level: 12
Points: 2,858, Level: 12 Points: 2,858, Level: 12 Points: 2,858, Level: 12
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 10, Got 10
I had a camera once (think it was an old Fuji) that had a setting that did weird things like this. No idea why as it was of no use at all. I seem to remember the blurb saying get "creative effects" or some such rubbish! Even my almost new Canon Ixus 800 has a "colour effect" setting which does something similar, though not quite as lary as that!
Might be worth checking all the camera menus to check you arent on any odd settings?? Probably not the answer - Im guessing its a faulty camera...!
