Originally Posted by Greg Hi
I have had very basic digital cameras for years. One like my current Sony 5MP camera W-51 model.
But seeing this thread here: Canon EOS 400D Digital SLR with 18-55mm lens £399.97
along with wanting a better camera for sometime, has got me thinking
The Canon EOS 400D, being an SLR how does it compare to a standard digi camera.
I see it is 10MP so it must take a good picture. Are the digi SLR cameras easy to use? I take it you just take a shot and review it like you would with a normal digi camera?
What are the main points that the SLR has over a standard digi camera. Apologies if these are obvious questions but I have never been into photography before so know nothing about it. I don't even know what SLR stands for.
Greg |
Im sure lots of learned guys ( and girls )here will fill in the gaps but Ill try
SLR stands for single lens reflex. Cameras designed this way allow you to see and frame for shooting exactly what the ( film or sensor in a DSLR) "sees" .
This means framing is virtually 100% accurate. It also means you view through the viewfinder as the image through the lens is projected there via a mirror or prism
As such DSLRs don't use an LCD for framing before the shot is taken . however you can see the shot image in the LCD after the shot is taken : this feature is common to
all digital cameras
In a non SLR camera there is an approximated view in a viewfinder or LCD.
The SLRs tend to have bigger image sensors, better image processing hardware and fitted in many cases with better lenses. they also tend to be much faster in operation and shutter lag ( that little gap between pressing shutter and actually capturing image is almost a non issue ) compared with non DSLRs. Thier auto focus mechanisms also tend to be much faster and more accurate.
Thier pictures ( taken) in lower light conditions tend to be "cleaner" (less noise)
In the above ways they may take a better picture on Auto setting but have more.
You have much more control over white balance, shutter speed , aperture, ISO and other setting as you can change them to get a better picture if the auto setting is not getting it right or a
creative effect is desired.
Finally you are not limited to the lens on the camera as they are designed to take various lenses . The advantage is that different lenses cover the ranges far better than an all in one. the disadvantage is cost ( sometimes lenses cost more than the body) and Bulk ( you need a bigger bag). Also the ability to change lenses also means the sensor is potentially exposed to dust each time you change a lens. DSLRs now have smaller models but are usually bigger than standard digicams
The 400Ds 10Mp works for it but it doenst take better ( more detailed) pictures than its 8Mp 350D younger brother or the 30D ( its bigger brother)
More pixels on a similar sized sensor means the pixels (photosites) have to be more light sensitive and this makes Digital noise more of a problem)
Similarly the 6Mp Nikons D /40/50/70/ and canon 300D will give you far superior images to many non DSLRs with more pixels.
DSLRs can be used as point and shoot , as such can be easy to use. Using them in a more advanced way ( for creative photography and more control over the outcome) can come with time as they are much more capable in this way
However being more capable has a few disadvantages
1)The results of "out of box "default settings may initially be underwhelming compare to a standard digicam
2) It takes time to learn the cameras to get the much better results (but IMO it is time well spent)
There are so called "bridge cameras" which have some DSLR features but have fixed lenses which cover a fairly useful range.Low cost DLSRs are now so low cost that the bridge cameras are needing to fight hard to justify their existence by beign better VFM and fitting lenses much better than the kit lenses that come with DSLRs
HTH... for now
