Help with Nikon D50 - menus
Old 06-04-2007, 9:42 AM   #1
5,243, Level: 17
Points: 5,243, Level: 17 Points: 5,243, Level: 17 Points: 5,243, Level: 17
Thanks: Gave 0, Got 2
Hi peeps,
I've just bought a new D50, my first DSLR, but am having problems with the menu selections.
I want to change the settings on the " Optimize Image" in the shooting menu, but it is not highlighted in black ( it remains in that shady grey colour). There are a number of other options too that remain in grey, but the manual doesn't explain why, unless I am missing something. Anyone point me in the right direction please?
Many thanks
Dean
Old 06-04-2007, 9:51 AM   #2
13,799, Level: 28
Points: 13,799, Level: 28 Points: 13,799, Level: 28 Points: 13,799, Level: 28
Thanks: Gave 536, Got 296
Re: Help with Nikon D50 - menus
Go to this link:
http://www.kenrockwell.com/nikon/d50.htm
His D80 guide really got me going with my camera.
Down the page you will see a similar guide to the D50.
A quick re-read of your post suggest that you haven't keyed in the Full Menu option on your camera.
Old 06-04-2007, 9:55 AM   #3
13,799, Level: 28
Just checked and on my D80 you go into menu, then the Spanner, then CSM/Set-up. You then key on full menu -OK -Done. This should give you all your options instead of them being greyed out.
Hope this helps
Steve
Old 06-04-2007, 10:12 AM   #4
5,243, Level: 17
Hi Steve,
I have tried your instructions, but it still doesn't show the full menu. On the D50 it is on the spanner, CSM, then simple or detailed setting. I've tried to change it to detailed, but nothing happens. I think I will give the dealer a buzz.
Thanks for your help
Dean
Grrrrr. They are closed today.
Old 06-04-2007, 10:15 AM   #5
13,799, Level: 28
Make sure you press OK after keying and also make sure you key on Done if this shows, otherwise it will just ignore your new setting onto detailed.
Old 06-04-2007, 10:18 AM   #6
13,799, Level: 28
I've found the relevent page on Kens site:
http://www.kenrockwell.com/nikon/d50...nus-custom.htm
You will really benefit from downloading his guide.
EDIT
Added:-
KenRockwell - Press MENU and select the pencil icon to get to the Custom Settings Menu.
First select the "Detailed" mode under Menu > Setup (wrench) Menu > CSM menu, otherwise you'll only to get the first few items!
Old 06-04-2007, 10:29 AM   #7
5,243, Level: 17
Hi Steve,
I've d/l Kens guide thanks and pretty much what you said yourself. The menu is showing as detailed when I go into the CSM part, but is still on simple when I go out, even after keying in enter ( doesn't come up with DONE). No big deal at the moment, but a bit annoying. I guess I'll have to wait til the dealer opens
Dean
Old 06-04-2007, 10:35 AM   #8
6,416, Level: 19
Points: 6,416, Level: 19 Points: 6,416, Level: 19 Points: 6,416, Level: 19
Thanks: Gave 33, Got 148
just a quick breeze through but what is you program dial set on? change it to P or A or something rather than a scene mode or auto. It should open up more options
Old 06-04-2007, 10:40 AM   #9
5,243, Level: 17
Ush you are a genius All sorted now, deep embarrassment
Dean
Old 06-04-2007, 10:47 AM   #10
6,416, Level: 19
no worries mate, i used to work at jessops and this along with the nikon D lens having to be on apperture f22 on an auto camera were the most common things people used to come in with scratching their heads (and often demanding refunds!)
