Originally Posted by iGiDK Sorry, but in my own opinion I don't think the HDR effect works in this shot.
HDR = High Dynamic Range: The jumble and high concentration of masts after the old spice boat are basically blocking out a lot of this 'range'
...and these are the areas of the photo that would normally be enhanced by the HDR effect as you are able to pick out areas of detail in subjects that are far away in the frame.
I think this could be a cracker if your viewpoint was from slightly higher up. Therefore you'd have the water, buildings and boats in the foreground, then the plethora of masts, then the architecture and then the sky.
I think I prefer your B+W shot of this harbour on your flickr page, it just looks a bit too jumbled for HDR.
Sorry! |
Thanks for the comments
I actually, totally agree with you. I've been looking at this all morning thinking it doesn't work and you have just explained what I couldn't see.
I also prefer the B&W one but I always prefer B&W to colour in the majority of shots anyway.
Thanks again mate.
Regards
Martin
P.S. Don't be sorry, I would rather receive opinions, good or bad, than none at all so that I can try and improve.
