HELP! 430EX "difficulties"!
Old 15-03-2007, 7:26 PM   #1
QuietRiot1983's Avatar
5,567, Level: 17
Points: 5,567, Level: 17 Points: 5,567, Level: 17 Points: 5,567, Level: 17
Thanks: Gave 52, Got 53
Ok, I received my speedlight this week, and have read the instructions from front to back...but I'm still confused!
Should the focal length indicator change as I change my lens' focal length?
Even when I press the "zoom" button, then the +/- buttons, it doesn't change...I'm lost!
Old 15-03-2007, 8:03 PM   #2
10,180, Level: 24
Points: 10,180, Level: 24 Points: 10,180, Level: 24 Points: 10,180, Level: 24
Thanks: Gave 316, Got 221
Re: HELP! 430EX "difficulties"!
From what I remember of the 580EX (when I rented it) the zoom indicator only changed when the flash was all the way down. In bounce mode (if there was such a thing) the zoom wouldn't change... is this the problem?
I'd be interested to hear what you thing of the flash, it may be the next thing I save up for (other than a circular polariser)
Old 15-03-2007, 9:05 PM   #3
5,567, Level: 17
Well I've only used it in full auto mode so far, but it's quick to recycle, the results look lovely and natural.
And weirdly, with it on, I feel much more pro!
salubrious_k (15-03-2007)
Old 15-03-2007, 9:37 PM   #4
Steve Zissou's Avatar
4,112, Level: 15
Points: 4,112, Level: 15 Points: 4,112, Level: 15 Points: 4,112, Level: 15
Thanks: Gave 7, Got 11
I have my 430 on Manual, and when I zoom in and out it doesn't change unless I half press the shutter release to focus. After that, if I zoom in and out, the flash does too, and you see the change on the LCD.
Old 15-03-2007, 9:48 PM   #5
5,567, Level: 17
Mine seems to just stay at 14mm, no matter what i do!
Thing is, I don't have a lens that's as wide as 14mm!
Old 15-03-2007, 10:22 PM   #6
Radiohead's Avatar
15,086, Level: 29
Points: 15,086, Level: 29 Points: 15,086, Level: 29 Points: 15,086, Level: 29
Thanks: Gave 327, Got 450
Has the 430EX got a wide-angle flap that comes down out of the front over the front of the flash. If that's down it'll always stay at 14mm, so push it back in.
Old 16-03-2007, 9:50 PM   #7
5,567, Level: 17
It stays at 14mm even when the wide angle diffuser thing is up and retracted...
Old 18-03-2007, 7:15 PM   #8
5,567, Level: 17
OK I solved it, the wide angle diffuser wasn't popping all the way back, so even when I thought it was back, the unit didn't.
